Yanmar FX24D
/ Yanmar FX24D #1
coolbrze
VA
Kubota MX5800
I'm purchasing a piece of property w/ a FX24D 4x4 tractor w/ bucket. What can you tell me about this tractor? Any help is greatly appreciated, thanks!
/ Yanmar FX24D #2
I can tell you to make sure you use an over run clutch when using a rotary mower or any other flywheel type implement. The rear end ring and pinion gears history on that series has proven to have some problems. However, used correctly, I doubt you will ever see any problems.
/ Yanmar FX24D
Thanks Winston1, what do you mean by using an over run clutch? By flywheel type implement, I assume that's anything that runs off the PTO?
/ Yanmar FX24D #4
OVER RUNNING CLUTCH- QUICK DETACH: Yanmar Tractor Parts This allows the implement pto shaft to continue to spin even though the tractor pto has stopped.
Rotary mowers, sometimes called bush or brush hogs have a flywheel inertia that will push your tractor forward after you push the clutch in which can be dangerous. Some pto implements like a tiller does not have that flywheel inertial so it might not be necessary to use the over run clutch with it but certainly no harm in using one.
tractorErnie, one of the Yanmar guru's on this forum has always recommended the use of an over run clutch, especially on the power shift models. Not only is safety involved with the over run clutch but also the bang that can happen to your differential when shifting the power shift at high speeds when mowing. Not good with words but hope I have explained well enough to convince you to get an over run clutch.
/ Yanmar FX24D
Yes sir, thank you very much!
/ Yanmar FX24D #6
Winston said the important stuff. Keep fuel and air filters in the tractor and keep it covered and water off of it as much as possible. Those tractors have lots of electronics on them and there are no English service manuals availible, and very limited knowledge state side about them. Parts availibilty also can be an issue on things other than common parts.
2021 John Deere 5100E (A64126)
2021 John Deere...
2019 John Deere 4044M (A62177)
2019 John Deere...
2019 Mercedes-Benz Sprinter Box 1500/2500 Van, VIN # WD4PE7ED3KT012316 (A65563)
2019 Mercedes-Benz...
John Deere Pallet Forks (A66285)
John Deere Pallet...
2016 TEXT 26ft T/A Dovetail Flatbed Equipment Trailer (A59230)
2016 TEXT 26ft T/A...
Landhonor 3Pt Potato Harvester (A66285)
Landhonor 3Pt...
