Yanmar FX22
/ Yanmar FX22 #1
martybhawk
Alabama
Yanmar FX22
Greenhorn just purchased FX22 to use on 2 acre property I will be building on. Seller did not know year of tractor or much about it, no manuals, etc. It has 1100 operating hours. It seems to be in excellent condition, everything seems to work. I am looking for sources to find as much info abt FX22 as possible. Anyone have a manual I can get a copy of? Anyone know how to determine the year? S/N is 00579.
/ Yanmar FX22 #2
Nice tractor.
I only know a little...
Manufactured from 1984-?
3 cyl, 25 engine HP - 22 PTO HP
D model weighs 2458. It is 113" long, 49" wide and 75" tall.
Several dealers and parts suppliers (here on TBN) will help you with manuals and parts.
Mark
/ Yanmar FX22 #3
I have a manual for the F series, published by Murray Publishing. I would only rate the manual as fair. The info that Mark gave is different than what is in my manual and I wouldn't want to hazard a guess which or maybe either being accurate.
Manual says engine is a 3TN84U-B with 1.46L in size. Operating range for engine is 1800-2400. Caps: fuel 6.5Gal, Cooling 1.2Gal, crankcase4.75qt, trans6.25qt.
The hyd are constant flow with 1991 psi max. Brakes are wet mechanical
I'm sure you Fx22 is not that much different than my Fx24 so if there are any specific questions you have, I might be able to help.
As for filters, here are the Baldwin xref numbers. Almost any major mfgr will have filters.
Oil = B179
Air = PA1690-FN
Hyd = BT371-10
Fuel = PF717
2013 Ford Taurus Sedan (A64557)
2013 Ford Taurus...
Trump 2028 Sign (A64127)
Trump 2028 Sign...
2005 Peterbilt 379 Extended Day Cab (A62613)
2005 Peterbilt 379...
Covered Livestock Mineral Feeder (A66408)
Covered Livestock...
VERSATECH 66" GRAPPLE RAKE (A64277)
VERSATECH 66"...
2016 Dodge Charger Sedan (A64557)
2016 Dodge Charger...
