yanmar diesel help
/ yanmar diesel help #1
zlock24
New Martinsville, WV
jd 445, kubota bx1500,wheel horse c-160, wheel horse h-520
I found a yanmar diesel that is a 18hp 3TNA68, but it is the same block as the 3TNA72 (455 diesel tractor motor), so i was wondering how you would crank up the juice to bring the engine into spec of 22hp. Any help would be appreciated, thanks.
/ yanmar diesel help #2
Well. The last two digits in a yanmar model number indicate the bore size in mm. So if those engines are indeed the same block, they are different displacement. Look for a screw on the injection pump that has a tamper evident coating on it. That's the one you want to tamper with to make BIG power!
/ yanmar diesel help #3
Sort of on topic.
Has anyone turned their pump up on a 455? How much and what was the performance like?
What is the chance of damage?
/ yanmar diesel help #4
Sort of on topic.
I turned the fuel up on a F935 with the same motor. More smoke....a lot more smoke and no real noticeable power increase. Unless yours will not smoke at all turning up the pump will not give you any worthwhile power increase. These small engines generally are working close to their limit and have very little room for increased power. Turbo charging will give you more but that is a whole new ballgame.
As for damage, likely not unless you run it past the smoke point. Smoke means excessive exhaust temps which will cause damage.
Frontier RC2060 (A64126)
Frontier RC2060...
2017 Caterpillar 259D (A64126)
2017 Caterpillar...
2025 IRET13 Electric Tricycle (A61574)
2025 IRET13...
Denyo DCA-600SPK 500kW Sound-Attenuated Diesel Generator (A63689)
Denyo DCA-600SPK...
Caterpillar 302.7D (A64126)
Caterpillar 302.7D...
2022 EZ-GO ELITE...
