Dirt Moving Yanmar C25R Track Dump
/ Yanmar C25R Track Dump #21
I have one of these as well. The previous owner that we bought our ranch from left it here (as well as a nice Komatsu dozer).
They are a solid little machine and built very well. We use ours primarily to move the rocks that I am constantly digging up. For that it works good.
/ Yanmar C25R Track Dump #22
Someone educate us laymen on the drive mechanism?? For example, hydraulic motor on each axle? Gear drive with an open differential and brake system for each side?
/ Yanmar C25R Track Dump #23
I've only seen two sizes offered as gray market imports, and I think Yanmar-USA only offers those two sizes. But a google search on 'yanmar tracked dumper' found Images from power wheelbarrow size up to dumptruck size.
Here's the C12R, the smaller one I was thinking of.
I think we'd make good neighbors ovrszd!
It has a 4 spd manual transmission with a separate FWD / REV lever. The only hydraulics are for the dump cylinder. Steering is clutch packs left and right side. It's a pretty simple design.
My $400 "parts" machine is now an excellent runner! I fixed the wiring, fuel lines, put in a new low pressure fuel pump and it fired right up! Runs awesome, steering is very responsive, brakes even work good! I went through and hit every grease fitting I could find and oiled all of the linkage.
/ Yanmar C25R Track Dump #26
Glad it worked for you. You deserve this equipment Happy. You'll keep it alive!!! :)
Thanks ovrszd!
Went out through the swamp today.
/ Yanmar C25R Track Dump #30
I love it!
Looks like heck > ... User neglect and abuse.
Runs like it should despite years of abuse > ... Yanmar quality!
/ Yanmar C25R Track Dump #31
Your just trying to make us all jealous with those pictures! :drool:
/ Yanmar C25R Track Dump #33
Would you take $500 for it? :D
Aaron Z
I never thought I'd be hoping for snow, but I'm dying to try it out in a heavy snowfall, I think I can wait til next year though.
/ Yanmar C25R Track Dump #37
I will give you $800 if you deliver it to my house:laughing::drool::moneybag:
/ Yanmar C25R Track Dump #38
Since you are sooo far away from me, hope you get your snow!!!! :D
Changed out the "mush" body mounts today. I ended up doing each side of the front mounts on both machines. Each machine had a bad right front body mount, leaking fuel on the rubber is the suspected cause? All leaky lines repaired as well.
Before
After
2012 LincolnMKX Hybird Sedan (A61574)
2012 LincolnMKX...
2016 Ford Explorer AWD SUV (A61574)
2016 Ford Explorer...
(25) 2" X 2" X 63" TUBING (A64280)
(25) 2" X 2" X 63"...
2024 Kubota M7-174D (Deluxe) 4WD Tractor - 244 Hours (A63688)
2024 Kubota...
Transfer tank (A61567)
2019 Ford F250 4x4 Crew Cab Pickup Truck (A64194)
2019 Ford F250 4x4...
