Dirt Moving Yanmar C25R Track Dump
/ Yanmar C25R Track Dump #21
I have one of these as well. The previous owner that we bought our ranch from left it here (as well as a nice Komatsu dozer).
They are a solid little machine and built very well. We use ours primarily to move the rocks that I am constantly digging up. For that it works good.
/ Yanmar C25R Track Dump #22
Someone educate us laymen on the drive mechanism?? For example, hydraulic motor on each axle? Gear drive with an open differential and brake system for each side?
/ Yanmar C25R Track Dump #23
I've only seen two sizes offered as gray market imports, and I think Yanmar-USA only offers those two sizes. But a google search on 'yanmar tracked dumper' found Images from power wheelbarrow size up to dumptruck size.
Here's the C12R, the smaller one I was thinking of.
I think we'd make good neighbors ovrszd!
It has a 4 spd manual transmission with a separate FWD / REV lever. The only hydraulics are for the dump cylinder. Steering is clutch packs left and right side. It's a pretty simple design.
My $400 "parts" machine is now an excellent runner! I fixed the wiring, fuel lines, put in a new low pressure fuel pump and it fired right up! Runs awesome, steering is very responsive, brakes even work good! I went through and hit every grease fitting I could find and oiled all of the linkage.
/ Yanmar C25R Track Dump #26
Glad it worked for you. You deserve this equipment Happy. You'll keep it alive!!! :)
Thanks ovrszd!
Went out through the swamp today.
/ Yanmar C25R Track Dump #30
I love it!
Looks like heck > ... User neglect and abuse.
Runs like it should despite years of abuse > ... Yanmar quality!
/ Yanmar C25R Track Dump #31
Your just trying to make us all jealous with those pictures! :drool:
/ Yanmar C25R Track Dump #33
Would you take $500 for it? :D
Aaron Z
I never thought I'd be hoping for snow, but I'm dying to try it out in a heavy snowfall, I think I can wait til next year though.
/ Yanmar C25R Track Dump #37
I will give you $800 if you deliver it to my house:laughing::drool::moneybag:
/ Yanmar C25R Track Dump #38
Since you are sooo far away from me, hope you get your snow!!!! :D
Changed out the "mush" body mounts today. I ended up doing each side of the front mounts on both machines. Each machine had a bad right front body mount, leaking fuel on the rubber is the suspected cause? All leaky lines repaired as well.
Before
After
New/Unused Wolverine 72in Tiller (A65583)
New/Unused...
2018 CATERPILLAR 320GC EXCAVATOR (A60429)
2018 CATERPILLAR...
3 Brake Drums (A62613)
EZ-GO GAS GOLF CART (A63276)
EZ-GO GAS GOLF...
Case IH 200 50' Field Cultivator (A66285)
Case IH 200 50'...
2018 Ford F-150 4x4 Crew Cab Pickup Truck (A59230)
2018 Ford F-150...
