Yanmar Block Heater
/ Yanmar Block Heater #1
Suds
Helena, MT
Yanmar 1610D
I have a YM1610d and want to install a soft plug heater. I called my local NAPA store and they weren't too helpful, there many heater configurations and I don't know what will work.
Has anyone installed a block Heater? If so could you tell me part no. and suppliers? How about replacement soft plugs?
Thanks. Suds
/ Yanmar Block Heater #2
Suds,
Go to your local JD dealer and ask them for a block heater for a 650 JD. That is what I used & it worked just fine
/ Yanmar Block Heater #3
I put a Yanmar block heater on my YM1301D last year and it works very well. It threads into the block on the exhaust side in place of a threaded plug. There were two on my tractor, and I used the rear one because it was more accessible. Here is the thread where I posted the information. Here is the meat:
For those interested, the Yanmar part number for the engine block heater that threads into the side of the engine block is:
Part# 2358980
Description: Engine Block Heater for 135, 155, 165, 169, 180, 186, 187, 195, 220, 240, 226, 276
It should work for your YM1610D.
Marv, Thanks for the information. I am heading for the mid
west and I should pass a JD Dealer.
Greg
I had to go out and look at my engine again, no threaded plugs, has driven in soft plugs.
/ Yanmar Block Heater #7
The screw in Yanmar heater will not work on a YM1500 & some of the US models . I sell a heater for the lower radiator hose for models without the threaded freeze plug.
/ Yanmar Block Heater #8
Suds,
My YM1301D has the standard freeze plugs on the intake side of the engine. On the exhaust side, there are two threaded plugs. I'm really surprised that the YM1610 doesn't have them.
/ Yanmar Block Heater #9
How did you get the plug out? I bought a Yanmar block heater from Len this spring and so far I have been unable to get the plugout. I used penetrating oil, Brutus(my frirnds large impact wrench), and plain old breaker bars and the only thing that happened is the 1/2" plug hole is starting to get out of shape. This is on a FX175D and the plug is on the exaust side. Any ideas?
/ Yanmar Block Heater #10
Mine came out very easily. I just put a ratchet extension into the plug, put my ratchet on, and turned it out. As I said, there were two, in the block area between cylinders. I chose to use the one toward the rear since the one closer to the front was partially obscured by the hydraulic lines (I think).
Did you try to remove both?
By the way, how do you like the FX175D? I think that would be the ideal loader tractor for my uses.
/ Yanmar Block Heater #11
Pochickenfarmer
I just put a block heater in my 790 JD it has a Yanmar engine. I ruined two 1/2 " extensions. I realized I didn't have the extension in far enough. I had to pound it in to the plug as far as it would go. My 650 pound impact would not budge it.
I used a breaker bar with about a four foot extension and it finally came out. I now have a breaker bar with a bend in it.
I don't know why they put them in so tight.
Good luck,
Mainiak1
/ Yanmar Block Heater #12
I can only get at the rear plug and it won't budge. I tried hitting the extension to loosen things up but a broken tractor is not going to do me any good. I tried the pipe "extension" and bent the pipe too. If I have to take the tractor to a shop for something I'll have them take a try at the plug. Maybe I'll look at a lower radiator hose heater. The tractor is in a barn all the time and so far starting (even in Minnesota) hasn't been a problem. I had an old Ford tractor to maintain 1000' of gravel driveway but after I paved the drive I wanted a smaller tractor for farm stuff. I love the FX175D for my needs. I have a 4' Allied loader and a 54" Yanmar tiller. I can't say enough about the Powershift.
/ Yanmar Block Heater #13
I usually tell people to try to remove the plug before ordering the Yanmar block heater. The head is usually not square , but rounded , so it hard to keep the socket on it.
2008 Case IH 2152 Combine Header (A63688)
2008 Case IH 2152...
2016 Ford F550 Crew Cab 4x4 Flatbed Truck (A62613)
2016 Ford F550...
Paladin 12in Digging Tooth Bucket Excavator Attachment (A64194)
Paladin 12in...
New/Unused CFG Industrial H15R Mini Excavator (A65579)
New/Unused CFG...
2020 Chevrolet Equinox AWD SUV (A61574)
2020 Chevrolet...
2025 Unused SDLGC80 60v Electric Golf Cart (A64194)
2025 Unused...
