Yanmar 1500
/ Yanmar 1500 #11
Thanks for the pricing information. The seller has it priced on the high end of your range. If I decide I am interested in getting it, I'll make a lower offer.
I don't think a good shape 1500D with good implements would be too over priced even if listed at just over $4000. I forgot that it was a D. And yes if it has a loader go get it at that price now!
Other thing to consider is was this a VN recon machine. They are valued somewhat less by folks as the quality of them can be questionable. If it has been in service for years and has several hundred hours on it, its probably fine. Mine and Neats are both recons. I have not really had any issues with mine. Knowing what I know now, I should of spent the extra few hundred dollars on a fredericks machine but that is a moot point at this point. Things to look for would be, If it has a laoder it will be a bulldog or VN brand on a recon. It wont have a PTO safety shield on it. My paint is off color, its closer to Kubota orange and actually may be Kubota orange, than yanmar red, But all are not this way, there is a chance that my sheet metal was just mixedup over there and the painter was painting kubotas and they got mine as well. I have one fender cap that is red, you can see the difference. Hoses and belts might say LCI on them. The decals and paint tape job do not look as professional as the fredericks ones.
But like I said if it has been in service and he is using it that's a true test of its performance. It should crank easy, letting you know it as decent compression, have little or no blow by from the tube when its warm. Exhaust should be on the clear side to slightly grey when idling and when at operating speed. (you may know how to tell a decent diesel, not sure?) You can have the lift in the air with an implement and then shut off the tractor to see if it holds the implement in the air or how fast it lowers, this will tell you the condition of the 3pt system internals.
Like California said these are simple machines designed to be maintained by a farmer or farm mechanic on the farm with most of the tools he would have.
/ Yanmar 1500
No it doesn't have a loader. No I am not an accomplished mechanic. I do have a mechanic friend that will probably be willing to go with me as an advisor if/when I decide to take a look. I appreciate all the good advice from TBN guys. Hopefully this will proceed in a positive manner. I'm sure other questions will surface.
/ Yanmar 1500 #13
We have had a JD 650 which is essentially the same as a 1500. No loader and mine is a 2wd. Since 1984 it has only needed regular oil changes and a handful of batteries. Great machine and with 4wd I'd be running to it.
/ Yanmar 1500 #14
Ok guys i have read through this post and have some similar questions. I am also looking at a Green 1500d. It has 786 hours on it. Guy says it runs great with no known issuers. It's 6 hrs from me so I haven't seen it. The pictures make it look pretty nice. I'm not sure what it's worth. I know a red one refurbished is $5100. So know sure what this green one is worth and I have some ideas of the differences between the red and green, but don't know all of them, or if it's worth buying a green 1500d?.... Or look for a red one? Any input would be appreciated. Also does the green 1500d have a foot throttle?
/ Yanmar 1500 #15
Be very careful regarding the hours on a Yanmar.
The hour meter is not the traditional hourmeter to tell you total run time becuase it rolls over at 999 hours.
It's main purpose is keeping up with scheduled maintenance.
td
/ Yanmar 1500 #16
Yep I totally understand how that works. I should have stated that it was approximate hours. Could be 2000 for all I know.
/ Yanmar 1500 #17
It has those funny little external headlight pods on some years...right? Has a side air cleaner. Left side as sitting on tractor I think. And some had left side exhaust I beleive.
I not positive but I want to say it should have a foot throttle?
/ Yanmar 1500 #18
Headlights I'm not sure about. Exhaust is on the right side and air filter is on the left side. I did call Aaron at Hoye today. Basically the green model has some minor differences. The brakes are harder to access, and the front axle is not as beefy as the red one. Keep in mind if planning on installing a FEL. Otherwise a good yanmar
/ Yanmar 1500 #19
right , I was thinking there was something to do with either the brakes or the axles and how the rear was done but couldn't quite remember
240156 (A56859)
240156 (A56859)
2008 KENWORTH T300 FLATBED FUEL TRANSPORT TRUCK (A58214)
2008 KENWORTH T300...
2021 Bronco Sport 4x4 SUV (A59231)
2021 Bronco Sport...
2014 SKYTRAK 10054 TELEHANDLER (A58214)
2014 SKYTRAK 10054...
2020 CATERPILLAR 306 CR EXCAVATOR (A60429)
2020 CATERPILLAR...
UNUSED 89" LAND PLANE (A52706)
UNUSED 89" LAND...
