Yanmar 1401D: Attachments?
/ Yanmar 1401D: Attachments? #1
Viperize
Murrieta, Ca
Yanmar 1401D
I have a Yanmar 1401D. I am wondering what size of brush hog and rototiller to get. Any suggestions?
/ Yanmar 1401D: Attachments? #2
Welcome to TBN! You will find just about everything you will need to know to keep your Yannie running right here on this board. A 40"-42" brush hog would be about the right size for a 1401D. Even with a cutter this small you will want some front weight as a counterbalance. And a 48"-52" tiller would be about right also. Yanmar 2-pt tillers ride very close to the back of the tractor, so front counterweights aren't as much of an issue with the tiller.
Are there differences in the PTO shafts, size, lengths, ect? What should I be looking for? Are there different shafts for different attachments?
/ Yanmar 1401D: Attachments? #4
The attachment should come with the shaft. The shafts can be quite expensive to buy so they are often removed from used equipment. A close coupled tiller must come with the drive shaft for I have found it just about impossible to find the correct replacement shaft. Your tractor will have the industry standard 1-3/8 6 spline shaft. This is a exceptionally common shaft.
/ Yanmar 1401D: Attachments? #5
If you haven't done so already...it's a good time to convert your two point to a three point hitch. It will standardize your tractor and allow you to use any three point implement sized for your 1401D.
Mark
/ Yanmar 1401D: Attachments? #6
I converted my 1401 to 3 pt. however I kept the attachment for my 2 pt. Yanmar tiller. I think the 2 pt. tillers operate better than those with the 3 pt. conversion.
/ Yanmar 1401D: Attachments? #7
Yanmar uses a 1200mm tiller with the 1401s. Basically a 48". If buying new, you might consider a 42" if your soil isn't real nice.
John Deere 920 (A64126)
John Deere 920...
John Deere 7300 (A64126)
John Deere 7300...
Skid Steer Blank Plate (A65640)
Skid Steer Blank...
2014 Volvo Sleeper Tractor (A62679)
2014 Volvo Sleeper...
2023 CATERPILLAR 262D3 SKID STEER (A65053)
2023 CATERPILLAR...
2025 Stump Grinder Hydraulic Mini Excavator Attachment (A61572)
2025 Stump Grinder...
