Yanmar 1401D: Attachments?
/ Yanmar 1401D: Attachments? #1
Viperize
Murrieta, Ca
Yanmar 1401D
I have a Yanmar 1401D. I am wondering what size of brush hog and rototiller to get. Any suggestions?
/ Yanmar 1401D: Attachments? #2
Welcome to TBN! You will find just about everything you will need to know to keep your Yannie running right here on this board. A 40"-42" brush hog would be about the right size for a 1401D. Even with a cutter this small you will want some front weight as a counterbalance. And a 48"-52" tiller would be about right also. Yanmar 2-pt tillers ride very close to the back of the tractor, so front counterweights aren't as much of an issue with the tiller.
Are there differences in the PTO shafts, size, lengths, ect? What should I be looking for? Are there different shafts for different attachments?
/ Yanmar 1401D: Attachments? #4
The attachment should come with the shaft. The shafts can be quite expensive to buy so they are often removed from used equipment. A close coupled tiller must come with the drive shaft for I have found it just about impossible to find the correct replacement shaft. Your tractor will have the industry standard 1-3/8 6 spline shaft. This is a exceptionally common shaft.
/ Yanmar 1401D: Attachments? #5
If you haven't done so already...it's a good time to convert your two point to a three point hitch. It will standardize your tractor and allow you to use any three point implement sized for your 1401D.
Mark
/ Yanmar 1401D: Attachments? #6
I converted my 1401 to 3 pt. however I kept the attachment for my 2 pt. Yanmar tiller. I think the 2 pt. tillers operate better than those with the 3 pt. conversion.
/ Yanmar 1401D: Attachments? #7
Yanmar uses a 1200mm tiller with the 1401s. Basically a 48". If buying new, you might consider a 42" if your soil isn't real nice.
2004 BMW 325ci Convertible Coupe (A62613)
2004 BMW 325ci...
New/Unused 3 Point Receiver Hitch Attachment (A65583)
New/Unused 3 Point...
24 Gauge R Panels (A65640)
24 Gauge R Panels...
2026 DEVELON DX27Z-7 EXCAVATOR (A64279)
2026 DEVELON...
PORTER CABLE AIR COMPRESSOR (A65643)
PORTER CABLE AIR...
1998 Dorsey 45' Aluminum Citrus Trailer (A64127)
1998 Dorsey 45'...
