yamnar 2000
/ yamnar 2000 #1
bruce60
Frisco
yanmar2000
Yamnar 2000 seems to be starving for fuel. It dies when in gear or just idling. It ran great today for about an hour. Thanks.
/ yamnar 2000 #2
Plenty of fuel? Clean fuel filter? No trash in tank where outlet goes out? Fuel cap loosened to prevent vacuum?
Was in running normal until today?
"It dies when in gear or just idling." It will run with throttle open and not in gear?
/ yamnar 2000
I will try gas cap remedy and post. Thanks.
/ yamnar 2000
Fuel cap remedy didn't work.
/ yamnar 2000 #7
If your old rubber fuel lines haven't been replaced,, now is a good time to do it.. They will go bad
/ yamnar 2000 #9
I had this problem when I first bought the 2000. On your Throttle arm hold it in place so it don't fall. Or keep your foot on the Throttle pedal. There's a Nylon washer in the Throttle linkage that goes bad, You can adj. it by the lock nuts. If that's the problem .
20ft Phelan Lowboy Trailer (A65563)
20ft Phelan Lowboy...
New/Unused 7ft Double Chain Sling (A65583)
New/Unused 7ft...
New 5/16" G80 Double Chain Sling (A62679)
New 5/16" G80...
2022 TEXAS PRIDE GOOSNECK (A65643)
2022 TEXAS PRIDE...
MILLER BOBCAT 250 PORTABLE ARC WELDER (A64276)
MILLER BOBCAT 250...
JOHN DEERE 606C - 6R30" CORN HEAD (A64277)
JOHN DEERE 606C -...
