yamar 2201 bd
/ yamar 2201 bd #1
unicorn
wichita ks
yanmar 2210bd
hey tractors lovers
I have 2210bd using antifreeze running ruff and smoke is heavy black and staining smoke when rpm is raised
/ yamar 2201 bd #2
Welcome to TBN. Sounds like a head gasket.. Ouch. :(
We not only have an app for this website.. We have a forum you can discuss your future repair.
Yanmar
Good luck to you -robert
/ yamar 2201 bd #3
:welcome:
/ yamar 2201 bd #5
hey tractors lovers
Welcome!
Before starting cold, remove the radiator cap. Then watch in there while someone starts the tractor. A rush of bubbles then or a little later as it warms up proves a bad head gasket (or worse ... - but less likely).
And if there is any question of coolant getting into the cylinders it is imperative to spin it with the compression released before starting it, to blow out the liquid. Water is uncompressible and can shatter a piston, bend a rod, etc.
2018 GENERAC MOBILE PRODUCTS  MTL6S (INOPERABLE) (A68842)
2018 GENERAC...
500 BBL FRAC TANK (A67714)
500 BBL FRAC TANK...
2016 MACK CXU613 SLEEPER (A67714)
2016 MACK CXU613...
2007 FRAC TANK 500BBL WHEELED (A68842)
2007 FRAC TANK...
Wolverine DB-15-84W 84" QA Angle Blade (A64912)
Wolverine...
2015 JLG G12-55A TELEHANDLER (A67714)
2015 JLG G12-55A...
