XJ 2025H lock out switches
   / XJ 2025H lock out switches #11
   / XJ 2025H lock out switches #12
   / XJ 2025H lock out switches #13
Goooooood News I have it running and moving it had been sitting for a while. Now the issue the bucket goes up and down ok but the tilt is stuck it will not pivot the bucket. Oh, the last fix was replacing the starter solenoid.
   / XJ 2025H lock out switches #15
Excellent! Glad you got her going. On your tilt, unhook your hydraulic couplers and snap them back in and see what that does for you.
Thanks for the thought I will try the couplers and maybe bleed the tilt actuators too.
I am a bit better at hydraulics although I would like to see an illustrated parts breakdown on the pump. hint hint.
One more thought how do they check the pressures or locations ie. ports plugs ? I can plumb up a rig to check these.
Well, it died again, this time I insert the key turned to the left light up the glow plugs then rotate the key to the right to start and hear a click or pop and the main instruments does not show a blank or dead wonderful start to the day. I pull the cover check the fuses and the 40 amp at the starter is good instrument panel still blank. is the safety controller part of the instrument panel or just another relay sized relay with the start relay
   / XJ 2025H lock out switches #18
The parts list shows 1 each or 3 different relays. Nothing specifically designated as a controller. 40007175 RELAY-START-TRG750, 40007122 RELAY-ENGINE STOP-TRG750, 40198043 RELAY-TWIN-TRG750 . There is an engine control G100S01-04 .
Below from the service manual.
Hi Tom,
So here we go I replaced the OEM start relay with an aftermarket relay and just ordered a new OEM relay. The aftermarket only worked a few times after. The next day then goes to start twisting it to the right then pops and nothing. It might be that the aftermarket relay was not strong to control the current anyway a new OEM relay is on the way. All the fuses are good again. ?????
Hi Tom,
Here is the latest. after looking around I looked at the fuse box and finally figured out that the wiring schematic is not the same as my tractor mine only has 3 fuses in the cluster not like the schematic here shows four fuses is there another schematic available.
Thank you for your efforts helping fix this thing.
500 BBL FRAC TANK (A58216)
500 BBL FRAC TANK...
Unused 2025 CFG Industrial H15R Mini Excavator (A59228)
Unused 2025 CFG...
167 (A52708)
167 (A52708)
Air Compressor (A57149)
Air Compressor...
Leer Camper Shell (A57454)
Leer Camper Shell...
Aluminum Bell (A57454)
