XJ 2025H lock out switches
   / XJ 2025H lock out switches
Hello Tom,
Yes I am still fighting with this on the engine this time. I changed the fuel filter, it was nasty, I let the filter fill and checked the bleed for fuel pretty much air-free. Tried to start and nothing used diesel starter fluid would fire momentarily. I guess I need to look at the injectors or just lead up that connection first. Any ideas on this.
Scott
   / XJ 2025H lock out switches #32
Did you crank the engine when you loosened the bleed screw?
Maybe maybe not I will try that tomorrow, Monday. My arms were not long enough thanks!
Hi Tom,
Long time no see, I replaced the positive battery cable it was defective on the battery end. Now I am getting a Code on the LED panel showing a "J-1" indication on the screen. What does that mean? As usual, any help is appreciated.
Scott
   / XJ 2025H lock out switches #35
Hmm. I don't see any info on there being trouble codes at all in the manual. I'll keep my thinking cap on.
Hey I am glad you responded. The new battery cable works it cranks well but I bled the screw and it will not fire up. Now that fuel line is clear from the junction where it splits off ok tried starter fluid still nothing. ??? Um I did this standing beside the tractor not in the seat if the seat was locked out not seating it would not start to begin with right ?
   / XJ 2025H lock out switches #37
No, it should start w/o being in the seat. Set your park brake. Did the J1 go away?
Yes it did go away might be a voltage low indication, Still nothing on the start up the fuel system needs to track this down Illustrations ?
I checked on the OP manual and looked at 5-25 and 5-26 followed the instructions no change
2010 MULTIQUIP 25KW GENERATOR (A58214)
2010 MULTIQUIP...
LOT: (3) Adjustable Steel Racking Sections, 9' W x 24" D x 56" H (CONTENTS NOT INCLUDED - DELAYED (A59076)
LOT: (3)...
(APPROX. 640BF) 1X6X6-16 WHITE PINE TONGUE & GROOV (A52706)
(APPROX. 640BF)...
2012 TALBERT 4-AXLE RGN TRAILER (A58214)
2012 TALBERT...
(2) MULE PLOWS & FERTILIZER DISTRIBUTORS (A52708)
(2) MULE PLOWS &...
2013 Dodge Charger Sedan (A55973)
2013 Dodge Charger...
