X585 W/45 loader lifting problem !
/ X585 W/45 loader lifting problem ! #1
Firetaz
JD-X585 & JD-214
I have a X585 that I've owned for about 3 yrs. Works fine and handles everything I need it to do. The problem I'm having is that when I put the loader on im not getting the lifting power I once had. If I try to pick up a bucket of topsoil it will lift no higher than about 3'. If I try to pick up my 62" deck or 47" blower it won't do it. Empty it raises and tilts fine. I just changed the filter and replaced the HY-Gaurd, didn't help at all. Any ideas as to what's causing the lack of lift power ?
/ X585 W/45 loader lifting problem ! #2
Lifting power comes from pressure. Loss of pressure usually means the flow is going elsewhere. Since it sounds like it is affecting all of the hydraulic lift functions I suspect it could be the system relief valve is stuck open.
/ X585 W/45 loader lifting problem ! #3
I would plug a guage into the quick disconnect ports to see what the pressure is, working properly I would expect 940 to 1000 psi.
Thanks, I will check both !
2022 Kubota Z422-54 Zero Turn Mower (A63689)
2022 Kubota...
New/Unused CFG Industrial MH12RX Mini Excavator (A65583)
New/Unused CFG...
New/Unused Wolverine Mini Combination Bucket (A65583)
New/Unused...
2018 JOHN DEERE 650K LGP CRAWLER DOZER (A65053)
2018 JOHN DEERE...
78in. Skid Steer Bucket w/ Blade (A65640)
78in. Skid Steer...
2012 Audi Q5 3.2 Quattro Triptronic (A62679)
2012 Audi Q5 3.2...
