wrench size for Cat 1 pins?
   / wrench size for Cat 1 pins? #1
daveinnh
Hillsboro, NH
Kubota L4310
I have several implements that have Cat 1 pins that have a nut to fasten. My 1-1/8 wrench was too small so I bought both 1-1/4 and 1-1/2. Too small and too big, respectively.
Before I return the wrenches and ask the hardware store to special order a 1-3/8, do these pins actually take a metric wrench size?
   / wrench size for Cat 1 pins? #2
1 1/4 should fit
   / wrench size for Cat 1 pins? #3
I think you'll find that a large cresent wrench will fit it.
   / wrench size for Cat 1 pins? #4
   / wrench size for Cat 1 pins? #5
Large cresent wrench fits mine also, although I do have sockets and wrenches. It is just too easy to grab the adjustable and head out to the tractor when I need to change a pin.
If you need a quickie wrench, a piece of plate and a torch will make one, just take the nut and trace it onto a piece of plate, and cut inside the line. Leave the piece as long as you think you need for a handle, and maybe bolt a piece of wood to it for a handle. Works great when you need a wrench but everywhere is closed on the weekend...
David from jax
   / wrench size for Cat 1 pins? #6
You cant tighten tight enuf with a crescent wrench. These should be tightened to about 500ft lb. Open ended wrenches will damage that sized nut at that torque.
larry
   / wrench size for Cat 1 pins? #7
Well,mine holds,I must have a torgue cresent wrench.
   / wrench size for Cat 1 pins? #8
larry
WHAT????? Get out of the laboratory and into the real world! :p
Troy
   / wrench size for Cat 1 pins? #9
Most Cat I pins use a 1-5/16" nut on a 7/8"NF thread. An open end wrench IS hazardous to use at the torque level required to keep these pins tight. I don't worry so much about damage to the nuts as my knuckles and other soft body parts.
The best method to keep these pins tight is to throw away the lock washer and use medium or high strength loctite on clean, dry threads and torque the nuts properly. If no torque wrench is available, all you can pull on an 18"- 24" wrench is probably close enough. I use a 30" drift pin through the lynchpin hole to keep the pin from turning.
We are not working on a Geo Metro here; this is a job for large tools.
   / wrench size for Cat 1 pins? #10
larry
Troy
I am. I use a good 1/2" impact wrench and hold until all progress stops. On an implement that has high inherent vibration & shock, like a bushog with trees, handwrenching is not enuf. You get movement at the joint and periodic retightening becomes necessary. If your joints are stable when tightened with an open end wrench you just arent using your implement hard enuf. :pX:p
larry
500 BBL FRAC TANK (A58214)
500 BBL FRAC TANK...
2025 Swict 84in Bucket Skid Steer Attachment (A59228)
2025 Swict 84in...
CATERPILLAR 21" PIN ON BUCKET (A52706)
CATERPILLAR 21"...
2011 GROVE TMS900E TRUCK CRANE (A58214)
2011 GROVE TMS900E...
16001 (A55853)
16001 (A55853)
2015 Acura ILX Sedan (A59231)
2015 Acura ILX...
