Would you buy again?
/ Would you buy again? #21
I might not buy again. My 4110 requires 1 hour of radiator cleaning for every 2 hours brush-hogging.
I'm not sure if other makes/models would be any better, but I will check very closely prior to my next tractor purchase.
/ Would you buy again? #22
Put me down in the ' buy again ' list. My 5035HST is one fine beast ..... on the other hand, the new Mahindra USA site is sure hard to look at with my old slow dial-up....but that is another story.... :)
/ Would you buy again? #23
I'd also buy again but go with the next size larger either a 30 or 32 HP. My 2615HST has been very useful since I bought it in 2004. I don't use it a lot since I only have a little over 400 hrs. on it in 7 years. Mainly for lifting heavy things, moving dirt and stone, moving trailers around, and winter plowing. I do my own service, repairs, greasing, etc. Oil changes are done every year and Hydraulic fluid every 150-200 hrs. (probably more than it needs)
/ Would you buy again? #24
As I understand it, the 4110 has an ongoing issue with radiator overheating while brush hogging. I think there is a fix for it by moving the battery. A friend has a 509 backhoe on his 4110 and runs the snot out if it running the backhoe with no overheating problems.
What I like about my 6520 is it has a removable screen in front of the radiator.
hugs, Brandi
/ Would you buy again? #25
5035 has the extra screen in front of the radiator, too. Anything like choping leaves, brush hog'n, etc. is hard on any tractor... air filter and driver, too..
/ Would you buy again? #26
I have a 4035 and love it. It is a beast of a machine.
I posted the same question on both the New Holland and Massey forums here. It only generated a few replies there. For Mahindra, it generated three pages worth of replies. That may say something about the machine, and it's owners. :thumbsup:
-Derek
/ Would you buy again? #28
hugs, Brandi
Yes - I'll testify to that. For 8 years/2000 hours I dealt with having to clean the radiator often when cutting while very dry, then early this year I dropped the battery down between the frame, out from in front of the radiator and now I can cut the full 6 hours without blowing the radiator out at all. I used to run it until the gauge was between 3/4 and hot, now it never reaches 3/4 even in 100 degree temps. I never thought that it would make that much of a difference but it did. I took the original battery tray and re-bent it to fit between the frame rails, drilled & tapped the frame rails for bolts to hold the tray down low just on top of the front axle mount. The top of the battery is now even with the bottom of the radiator.
/ Would you buy again? #29
-Derek
I doubt that you will find very many unhappy Mahindra owners. There are always some lemons with every make and model, but overall Mahinda has a very good product. That's not to say that the other makes are bad, they all have some pretty good machines. :thumbsup: :thumbsup:
/ Would you buy again? #30
My battery is lowered and I have screens in front of the radiator. I end up in a lot of tall fluffies.
Like I said, it may be a problem with any tractor ... it's a major PITA
/ Would you buy again? #31
hugs, Brandi
I have the screens, but the problem is still there.
I can do FEL work for weeks w/o any problems. Hoever, if I get into tall dry stuff, the radiator is plugged in no time.
/ Would you buy again? #32
I had this problem the first time I brush hogged with our 4025. I just thought it was because the grass was so dry. I was thinking of just putting some cheap fiberglass filter material in front of the radiator and just change it out as needed.
/ Would you buy again? #33
This is a common issue with compact tractors. Especially in dry conditions.
/ Would you buy again? #34
Even as I have stuff clog the front screen while mowing, I never had an overheat problem. Guess the Big RED Beast's radiator has more than enough surface area.
hugs, Brandi
/ Would you buy again? #35
I bought a new 6530 about 2 months ago and it has had a oil seal that has went out 2 times in 50 hours. That don't even make me dislike it. That can happen to any of them but this is the best tractor
I have ever had:)
/ Would you buy again? #36
Absolutely would by another Mahindra. My 5530 is a beast of a machine, be sure to load the rear tires!:D:thumbsup::tractor:
Great replies everyone, really an encouragement. We should be buying towards the end of the year. We have lots of work to do around here, so a rugged reliable machine will be very welcomed. :thumbsup:
-Derek
/ Would you buy again? #38
Yes, I would absolutely buy another one, without hesitation.
/ Would you buy again? #39
I put my 2016 to work the day I bought it and just about everyday since. No complaints. I bought it used. Shopped around. It came with a front loader that I did not think I would need. WOW! Was I wrong. It is absolutely the handiest implement I never thought I would use!. Yes...I'd buy again
/ Would you buy again? #40
I've owned a 2015 for 2 years. It was 6 yrs old when I bought it. I love it.
It's strong, and well built.
I drove big ford and case skipploaders at work sometimes...I prefer my 2015.
2000 Artic Cat ZR600 Limited Edition Snow Mobile (A62613)
2000 Artic Cat...
2014 Subaru Legacy AWD (A62613)
2014 Subaru Legacy...
2006 Ford F-350 12ft. Flatbed Truck (A61573)
2006 Ford F-350...
6' STACKING RAKE (A64276)
6' STACKING RAKE...
CASE 588H ROUGH TERRAIN FORKLIFT (A64276)
CASE 588H ROUGH...
2014 Dodge Grand Caravan Van (A61574)
2014 Dodge Grand...
