MoreCowbell
I've posted many times to this site, but this time it feels a little weird since it has nothing to do with my tractor. However, I always get great feedback, so here it goes:
I am fabricating new steel columns for my crawlspace-to-basement conversion project. I am using 1/2" steel for the top and bottom plates with 3.5" schedule 40 steel pipe in the middle (walls just shy of 1/4" thick).
I am a novice, self-taught, stick welder. I use a 240v AC-only Harbor Freight special I got on eBay for $38. I had it set at about 95A and used 3/32" 7013 rods to weld the top plates on.
My problem is that it looks like I will need to weld the base plates to the pipes once everything is in place below the house. I do not have a 240v/50A outlet down there. However, I do have several 120v outlets. I would love to use this as an excuse to pick up a 120v wire feeder and learn how to use it. My question is whether a 120v unit would have the power to weld the thickness material I am working with. I should note that these welds would not be structural in terms of supporting the house. They only need to provide lateral resistance if the columns get knocked into.
Thanks.
Thanks.
