Worst stuck pics
/ Worst stuck pics #312
I think you fellas might want to let things dry out a little down there.
Yeah you sure have to watch out,places that haven't ever had issue will sneak up and get you. When we got stuck is in are bottom when in dry's up in usually August we get after it,cause two days after that pic it was all full again that tractor would been setting in few inches of water.
/ Worst stuck pics #313
Same land clearing job, but the initial stumping. Good thing my wife [literally]
was there with the ole Kubota to pull out the John Deere 850!!
Did she come right from the wedding?:D
/ Worst stuck pics #314
:eek:
:confused2:
/ Worst stuck pics #315
Hope they got heavy duty pressure washer.
/ Worst stuck pics #316
WOW - the ground does not even look that bad to bury a machine like that.
/ Worst stuck pics #317
Gotta get stuck couple times a year right..I live not even a half mile from the bay in Michigan, always wet behind my place, but got to try and get out there, guess years ago they use to farm this, but I have no idea how. It's not tiled and too small to get tiled...5 acres. I push it ice fishing too.. hahahaIMG_20181212_151944.jpegIMG_20180507_195931.jpegScreenshot_20190316-131839.jpegIMG_20190316_103210.jpeg
/ Worst stuck pics #318
These last two post show pictures how the tractors got stuck, but not showing how they got unstuck, getting stuck is one or two ways but theres probably over 100 different ways to get unstuck. I know people get anxious and put their rototiller on the tractor to start their garden but when theres still snow on the ground that's a good sign of to early.
/ Worst stuck pics #319
The first picture I wasn't rototilling, I had the forks on and pulling shrubs and small saplings, the ground was frozen and I happen to take the same path too many times, wasn't tilling but the tiller is what got me stuck, without that I would of been able to get out but not with that extra 900lbs on the back and couldn't lift any higher
/ Worst stuck pics #320
You won't get stuck if you keep moving.
Bruce
CAT FORKS W/ QUICK CUPPLER ATTACHMENT (A60736)
CAT FORKS W/ QUICK...
Champion Vibratory Roller (A60462)
Champion Vibratory...
Hay King 12' Pasture Renovator (A60462)
Hay King 12'...
3PT Boom Pole (A60462)
KNOW BEFORE YOU BID - DO YOUR HOMEWORK AND BE HAPPY WITH YOUR PURCHASE (A62129)
KNOW BEFORE YOU...
CASE INTERNATIONAL 5140 TRACTOR (A52707)
CASE INTERNATIONAL...
