Worst stuck pics
/ Worst stuck pics #301
I don't think I'd put the truck in between the two tractors and pull like that!!
Rob
/ Worst stuck pics #302
Rob
It looked like they were just using it as an anchor and winching with the truck.
/ Worst stuck pics #304
Yes sir your right it's just holding my truck and it still drug both few inches lol.
/ Worst stuck pics #305
Yep, been there, done that. Look closely and see the chain from the drawbar to the big steel post at the gate:
/ Worst stuck pics #306
I thought was going to have to double line but it finally broke suction,that 12k single lined it was all it wonted.
/ Worst stuck pics #307
image.png Buddy of mines current situation that lives few hrs from me,they have got a backhoe stuck now trying to get it out lol
/ Worst stuck pics #308
image.png my parents neighbor happened month or so ago. They brought in trackhoe to pull them all out lol. I have seen more but just didn't get pic lol
/ Worst stuck pics #309
/ Worst stuck pics #310
Yes and yes. The different reason was to connect the cut down jumper cables that were plugged into the Anderson connector, to the battery. Then I left it up to protect the windshield :thumbsup:.
/ Worst stuck pics #312
I think you fellas might want to let things dry out a little down there.
Yeah you sure have to watch out,places that haven't ever had issue will sneak up and get you. When we got stuck is in are bottom when in dry's up in usually August we get after it,cause two days after that pic it was all full again that tractor would been setting in few inches of water.
/ Worst stuck pics #313
Same land clearing job, but the initial stumping. Good thing my wife [literally]
was there with the ole Kubota to pull out the John Deere 850!!
Did she come right from the wedding?:D
/ Worst stuck pics #315
Hope they got heavy duty pressure washer.
/ Worst stuck pics #316
WOW - the ground does not even look that bad to bury a machine like that.
/ Worst stuck pics #317
Gotta get stuck couple times a year right..I live not even a half mile from the bay in Michigan, always wet behind my place, but got to try and get out there, guess years ago they use to farm this, but I have no idea how. It's not tiled and too small to get tiled...5 acres. I push it ice fishing too.. hahahaIMG_20181212_151944.jpegIMG_20180507_195931.jpegScreenshot_20190316-131839.jpegIMG_20190316_103210.jpeg
/ Worst stuck pics #318
These last two post show pictures how the tractors got stuck, but not showing how they got unstuck, getting stuck is one or two ways but theres probably over 100 different ways to get unstuck. I know people get anxious and put their rototiller on the tractor to start their garden but when theres still snow on the ground that's a good sign of to early.
/ Worst stuck pics #319
The first picture I wasn't rototilling, I had the forks on and pulling shrubs and small saplings, the ground was frozen and I happen to take the same path too many times, wasn't tilling but the tiller is what got me stuck, without that I would of been able to get out but not with that extra 900lbs on the back and couldn't lift any higher
/ Worst stuck pics #320
You won't get stuck if you keep moving.
Bruce
2022 Mack Anthem T/A Wet Kit Day Cab Truck Tractor (A66736)
2022 Mack Anthem...
KALMAR AC P50BX-PS WAREHOUSE FORKLIFT (A64276)
KALMAR AC P50BX-PS...
CAT D6T SU Blade (A68134)
CAT D6T SU Blade...
2009 VOLVO VHD BOBTAIL VACUUM TRUCK (A63569)
2009 VOLVO VHD...
Sandblast Pot (A68134)
2021 Bobcat T66 Compact Track Loader Skid Steer (A66734)
2021 Bobcat T66...
