Tires Worlds largest turf tires?
/ Worlds largest turf tires? #1
voodoo
N. Ireland (UK)
Iseki TE 4270
Just saw this Ford 1920 for sale on e-bay UK.
I have never seen turfs this size before. It makes "galaxy's" look skinny.
Anyone able to beat this on a compact?
Ford 1920
/ Worlds largest turf tires? #2
Looks like the turf tires on the tractor being serviced when I picked mine up. They were on a Kubota used on a golf course and looked at least that wide. Really impressive in person.
/ Worlds largest turf tires? #3
Ha! I didn't know they made funny tractors! /forums/images/graemlins/grin.gif You know like those drag racing cars! LOL!
Hypernix
/ Worlds largest turf tires? #4
Check this out. I think they look nice with the large tires
/ Worlds largest turf tires? #5
And this
/ Worlds largest turf tires? #6
What is the significance of such a large tire? /forums/images/graemlins/confused.gif Gerard
/ Worlds largest turf tires? #7
I'm thinking the guy has a hole cut in the floor of his cab too. In the winter he drives the heated cabbed tractor out on his frozen pond and ice fishes through the hole in the floor of the cab. He has built in flotation so he really doesn't worry too much about thin ice. Can you say "fish fry?" /forums/images/graemlins/grin.gif
/ Worlds largest turf tires? #8
Been there...Done that !! Here's a Pic of our former 'bota with the pro-street turf tires.....I bought them as take offs from a ford 1720 or 1920 in the mid 90's and bought floater type rims (that almost fit) had to machine the lug holes out a little from the US bolt pattern to fit the metric pattern 'bota. they're still on it.........The bota retired to florida & now works part time for a relative. The ride difference over the original rice type tires was amazing........& no ruts in the yard.............
/ Worlds largest turf tires? #9
They look like they could be used for rolling the lawn too!
/ Worlds largest turf tires? #10
</font><font color="blue" class="small">( 'bota with the pro-street turf tires )</font>
I like that kinda talk! You Hot Rodder. Ever since I saw your refrigerated gas pump I knew you were a little Gearhead like ME /forums/images/graemlins/cool.gif
My old MF135 has fairly large diamond cleat turfs and the ride is noticably smoother than the 1433v with r-4's of the same size 14.9-24 To be fair though the diamond tires only run 8lbs of air so they'll hook-up of the line /forums/images/graemlins/grin.gif
Certainly should be stable on cross slopes.
Might be prone to sliding though /forums/images/graemlins/blush.gif
/ Worlds largest turf tires? #12
If nothing else you can always use the tractor to roll the lawn. That is if the loading is still high enough!
/ Worlds largest turf tires? #13
</font><font color="blue" class="small">( Looks like the turf tires on the tractor being serviced when I picked mine up. They were on a Kubota used on a golf course and looked at least that wide. Really impressive in person. )</font>
With those babies you could drive on the greens without any damage /forums/images/graemlins/grin.gif
/ Worlds largest turf tires? #14
Mowing turf where tire marks are not acceptable(golf courses ect). The wider the footprint, there's less contact area per square inch. If your 12.6x16 tire puts 50lbs/sq", an imaginary 25.2x16 tire would theoretically cut that contact pressure in half, to say 25lb/sq". Less contact pressuree, less marking.
/ Worlds largest turf tires? #15
</font><font color="blue" class="small">( What is the significance of such a large tire? )</font>
Gerard,
For some reason over there in the UK, they insist on doing things like golf courses etc. on peat fields. Peat is extremely soft.
phil
/ Worlds largest turf tires? #16
I've seen super wide turf tires on sod farms in Northern Indiana.
/ Worlds largest turf tires? #17
bearing on ground, for a pneumatic tire, is the psi you put in the tire ...then, the weight of the vehicle equals the combined area of all the (four) contact patches times the psi ...
/ Worlds largest turf tires? #18
Thanks guys. Gerard
/ Worlds largest turf tires? #19
Kinda makes it look like a hot rod!
/ Worlds largest turf tires? #20
Here's my HOT Rod !! So far I love my turfs although I originally wanted R4's. They do give the tractor a more rugged, heavy duty....ok.... cool look !!
2008 Toyota Camry Sedan (A64557)
2008 Toyota Camry...
2013 Chevrolet Silverado 3500HD Enclosed Service Truck (A64194)
2013 Chevrolet...
20ft Bi-Parting Gates (A65583)
20ft Bi-Parting...
New/Unused AGT 3000PSI Hot Water Pressure Washer (A65583)
New/Unused AGT...
(1) Small Livestock Feeder Gate (A66408)
(1) Small...
2006 Generac SD0150 187kVA T/A Towable Diesel Generator (A61572)
2006 Generac...
