Workshop building the wrong way around ;)
/ Workshop building the wrong way around ;) #1
Renze
Super Member
the Steernbos (Holland)
Zetor 3011, Zetor 5718
Since August i rent a place with a workshop. That means, its a chicken barn with a wooden roof structure that was severely sagging, despite previous patchwork. Together with some other folks who have a section of that barn as workshop for their derby racing cars, we started to fix this section of the barn too before i officialy start to rent it: They had built the roof in 1965, yet we are putting up a supporting structure anno 2012 ;)
This is how we started: the roof was supported by a temporary framework on adjustable construction struts:
Here we put the two frameworks on either side of the wooden frame, sawed the wooden frames (now shop heater wood) down and welded a new steel frame underneath, built as measured.
A detail of the gussets in the corners
the 2nd wood frame is chopped to pieces and in the back of the barn (we needed some planks to level the top section of the rear wall)
overview of the barn with steel structure. This gives me a lot more clearance to put e.g. a dumptruck upright in the shop, or an overhead crane.
just another
rough sides that were exposed with the higher ceiling, clad with plywood
first section isolated with styrofoam plates...
Pallet of 3 Large Electric Motors (A62679)
Pallet of 3 Large...
2023 Kubota Z252KH-54 Zero Turn Mower (A63689)
2023 Kubota...
2014 International WorkStar 7300 4x4 Altec A55F 55ft. Material Handling Bucket Truck (A60460)
2014 International...
2019 FORD F-150 STX CREW CAB TRUCK (A63276)
2019 FORD F-150...
2014 Ford F-550 Altec AT40M 40ft Material Handling Bucket Truck (A61568)
2014 Ford F-550...
2015 Kenworth T880 QMC 8060R 40 Ton Tri Axle Straight Boom Crane Truck (A64194)
2015 Kenworth T880...
