Workmaster 60 dies in neutral
   / Workmaster 60 dies in neutral #11
Thank you sir. The relay in the safety circuit or module was bad. Popped a new one in and back in business. Back to loading logs on the sawmill.
De nada! That is what we are all here to figure out together! Glad I could help
   / Workmaster 60 dies in neutral #12
got my hands on a shop manual. The trouble shooting page leads me to three things, range switch (I know this is good), safety module, and 3A diode. I can't find anything else in the manual that shows where the 3A diode is or what the safety module consists of.
The Farmall A electrical diagram shows the 3A diode (part 84209114) connected across terminals 30 & 86 of the STOP LIGHT relay (i.e. rear stop lights).. You might want to try swapping the WORK LIGHT relay with the SAFETY RUN relay to test it. The 3A diode connector is as shown below. Hope this helps.
   / Workmaster 60 dies in neutral #13
Do you remember which relay it was. I'm having the same issue. Every gear is in neutral but tractor shuts off when I get off the seat.
   / Workmaster 60 dies in neutral #14
Hello,
In the event you don't receive an answer from the poster..
Left front of machine are 2 relay/fuse boxes. Box closest to the seat (back of machine and has fuses in top half ) has a relay labeled "Safety Run" (bottom right- see attached pics).
   / Workmaster 60 dies in neutral #15
Thanks that fixed it. 5th factory relay I have had to change in the last 2 years. At this point I may swap them all out.
Hello,
   / Workmaster 60 dies in neutral #16
Glad it worked! 👍
I purchased 10 exactly the same (id#, markings, etc) on ebay for $4/ea of that type/style relay.
The other 2 larger pcm relays on left side, by fuel tank, I was unable to locate except thru dealer (Messicks) which were $40/ea.
The other thing I did was jumpered seat switch (I stand a lot-no cab), so my seat switch doesn't cause no start or no run if I'm not sitting.
scott
2008 Genie GTH-844 Telehandler (A57453)
2008 Genie GTH-844...
Forklift (A59228)
Forklift (A59228)
2015 UTILITY VS2RA 48FT REEFER TRAILER (A59575)
2015 UTILITY VS2RA...
2013 FREIGHTLINER CASCADIA (A55745)
2013 FREIGHTLINER...
2014 Lamar Trailer (A55973)
2014 Lamar Trailer...
2022 Polaris Ranger 900XP 4x4 Utility Cart (A55853)
2022 Polaris...
