Workmaster 40 starting/electrical issues
/ Workmaster 40 starting/electrical issues
Did you check all the safety switches? On my TC26DA I had a problem and found one of the sensors (forget which one, but think for PTO) wasn't being fully engaged and a small adjustment there fixed iit. Whenever it works for a solenoid jump and not from the seat I suspect one of them. The PTO one is particularly finicky because it's designed to be run when the seat isn't occupied, but not allow a start when it's not fully in the "not engaged" mode. The TC26 had a button, I think that worked off the lever. My Workmaster 40 is a different one from yours and I don't have a clue how even mine works yet..
Hey there, thanks for the reply. I forgot to update this thread. As a few folks mentioned, the ground was at fault. The bolt on the frame side is somehow coming loose. I occasionally need to crank it back tight.
/ Workmaster 40 starting/electrical issues #12
Good to hear it's all working fine for you, good luck in the snow.
/ Workmaster 40 starting/electrical issues #13
Glad to learn you got it fixed and thanks for letting us know what your issue was so that others can benefit if they have a similar problem.
Miller Millermatic 212 Auto-Set MIG welder (A61307)
Miller Millermatic...
2020 PETERBILT 567 (A58214)
2020 PETERBILT 567...
MASSAGE CHAIR (A58214)
HUSQVARNA RIDING MOWER 46IN DECK (A56859)
HUSQVARNA RIDING...
2011 John Deere 5085 70HP Utility Tractor (A60352)
2011 John Deere...
2001 Toro Reelmaster 5400-D 100in Commercial Fairway Reel Mower (A59228)
2001 Toro...
