Woods Stump Grinder
/ Woods Stump Grinder #101
I just opened up an old thread here. Great info here and just have a few questions for those who know. Cabelas has a pto stump grinder as part of their WLM products which is made by Woods and according to Woods the exact same thing as the TSG50 just green paint. Cabelas has it on sale now for $3350 which is way lower than my local dealer who wants $4700 for the Woods unit. My Kioti DK50 has one remote. I checked out surplus center for a rear valve that I could use with the grinder. Could anyone steer me towards the valve that would work best for a single rear remote?
This is what I use and it works great.
http://pages.ebay.com/link/?nav=item.view&id=391033823049&alt=web
/ Woods Stump Grinder #102
It looks like I would have to modify my bracket in the rear since my ports are one on top of the other not side by side. What about a cheaper mechanical not electrical version?
/ Woods Stump Grinder #104
1/2" NPT 20 GPM DOUBLE SELECTOR VALVE
I came across this. It looks like it will work unless I am missing something. What do you think?
I have a Woods sg50 and that valve will not work on its own nor do you need one rated for that high of flow. That valve would only control one of the functions, either up and down or the swing left and right. That is a good price on the Cabellla model. See if it comes with the valve "tower" valve mounting bracket.
I don't have it in front of me right now, but you need a valve that looks like what you posted only with two handles (2spool) or a FEL loader type valve, then you can control the up down and swing functions. Maybe one of the resident hydraulic experts will post a couple examples.
Below are a couple examples of style, but I forget some specifics of a single remote as you have and how mine is plumbed off of my single BH line. So due diligence on specifics is required.
2 SPOOL 8 GPM PRINCE MB21BB5C1 DA VALVE
2 SPOOL COMPACT 10 GPM JOYSTICK CONTROL VALVE
I have the FEL type valve and if I had it to do over I would recommend the two single handles for better control of each function. Also, I have flow restrictor fittings on each line and would still consider an adjustable restrictor to feather flow even further.
Btw, your dk50 would run that grinder very well.
/ Woods Stump Grinder #105
I would highly recommend the electronic diverter I posted. Will make motion transitions extremely fast and efficient. I would not want to use a manual lever for stump grinding.
/ Woods Stump Grinder #106
I don't have it in front of me right now, but you need a valve that looks like what you posted only with two handles or a FEL loader type valve, then you can control the up down and swing functions. Maybe one of the resident hydraulic experts will post a couple examples.
Btw, your dk50 would run that very well.
Doesn't this valve just control which ports(cylinder) are used and then I control the flow with my rear remote lever?
/ Woods Stump Grinder #107
TSO, I just read your link more closely, I understand part of the description, but where it states, operated with the tractors lever remote. Could you explain a little further on how this would work with a grinder for example. Can you control speed of swing etc.? Thanks.
/ Woods Stump Grinder #108
My rear remotes are controlled with a lever right next to my seat. Pulling the lever in either direction will switch flow direction. I use this lever right now to control my snowblower deflector either up or down. I just called surplus center and he said that the valve I posted will work. He also directed me to an electric version which I like. I like the one TSO posted also. Just unsure about my ports lining up with it. I asked surplus center about flow restrictors for the hoses and he said he does not carry them.
/ Woods Stump Grinder #109
The flow restrictor fittings came from Woods...you can download a parts/manual on the TSG50 from their site. They were a couple bucks each. Surplus center does have a small adjustable flow restrictor that would work even better.
I see what you are saying, different than my setup. Where will you mount the valve? Is the electric diverter similar to what TSO linked? Maybe with electronic control the feathering or flow restriction will not be needed. I will need to look at these more closely to see if it would work better than a manual valve.
/ Woods Stump Grinder #110
The electric one surplus sells is a stripped down version for $309 vs $500. I cannot find the adj flow restrictors on Surplus website.
/ Woods Stump Grinder #111
First, my ports would not line up directly either, so I installed my actual hydraulic lines for my remote directly into the diverter, & I made my own mounting brackets for the diverter. I have a thread on here from last year where I did this, look through my started threads and you should find it.
and for clarification regarding operation, let me try to explain. I grind a lot of stumps. not only for myself but also commercially. Many times, you will find that you need an immediate, & I truly mean immediate, flexibility to either swing the boom left or right, or lift the wheel up or down. more specifically, you will find that you need the availability to lift the wheel in a split second so you don't bury the grinder or bog the engine when the grinder plunges after it hits a soft spot in the stump and you end up literally biting off more than you can chew.
the way I routed mine, is that my remote lever naturally operates the boom swing from right to left and back. When I press the button that comes with the diverter kit, which I mounted onto my remote lever, it instantaneously changes the flow to the opposite diverter valve, and keeps that flow directed until you release the button, and then it returns to the natural left or right swing. so, in an instant, by pressing the button where your thumb is already resting on the remote lever, you then pull back on your remote lever and it lifts the grinder. to return the grinder down you simply push forward on your remote lever with your thumb still on the button. As soon as you release the button, it instantly switches back to the other diverter side, and your remote lever controls left and right again. it amazes me how quickly the diverter switches positions for you, and once you get the hang of it, it is thoughtless and absolutely instantaneous.
I was a little skeptical at first, wondering if the $500 would be money well spent, but boy am I glad that I went with this diverter, & I truly would not want to grind stumps without it. It is well worth the money.
and, I apologize for the lack of capital letters in this post, apparently my speech to text on my phone doesn't want to make capital letters today.
/ Woods Stump Grinder #112
/ Woods Stump Grinder #114
Hey thanks TSO for the description of the electric valve. Now I have to read your other link and figure out how to apply all the info!
/ Woods Stump Grinder #115
No prob. I will even say, that even if I had a second set of factory remotes, I would still prefer to use the electric diverter with the grinder and split the 1 remote, specifically because of the instantaneous directions changes.
/ Woods Stump Grinder #117
TSO
I think you convinced me to go the electric route. Thanks
Yeah... I like spending other people's money lol
But seriously, for most other applications where you want to split a single set of remotes into two sets, I would say the manual diverter for less money would be a fantastic route. But in this situation, and it may be one of the only situations where it applies, you really benefit from having that instantaneous control. in the grand scheme of things, when you're already spending several thousand on the grinder, spending a couple hundred more to get the more appropriate tool makes logical sense.
Been some time since I looked at this old thread.
One thing I would recommend is to operate your stump grinder hydraulic cylinders via your loader joystick valve. That would require either removing your loader or using other hydraulic lines to operate the loader. I just used the rear ports and scv valve to operate the lift cylinders and that worked for me.
Operating the stump grinder with the joystick valve is VERY fast and quite intuitive during operation. Works better than a bunch of levers and switches.....IMO.
I likely need to overhaul my grinders joints now. Seems they got loose and sloppy....which makes the grinder jump around too much now. Results in a stalled tractor too often.
I got over 2000 stumps ground from my property with my grinder......so I suppose the joint issue is par for the course.....still.....I wish the joints had held up better.
I still have the original teeth on my unit. The cutting head seems bullet-proof.......I wish I could say the same for the joints.
I had my property "logged off" this year......and took about 60% of the remaining pine timber off this land. I got more work to do now.....so I better get those joints up to speed this spring. I have broken one of my drag links twice now.....and I attribute this to the stump grinder. I had the link welded to repair the first time......but replaced it the second time it happened. $300 - ouch.
One can exert allot of pressure with that swing cylinder......and you need to be aware of the pressure you can exert.....lest it cost you.
They took over 10,000 trees off my land.......stump henge. Grin. I doubt I will grind 500 of them and I am done grinding for a while.
/ Woods Stump Grinder #120
Interesting that the joints are going on yours.
Mine seems to be beating itself up (I'm beating it up) at the "ear" that the right side lower lift arm attaches to.
It has bent backwards towards the grinder wheel, which has put quite an angle on the lift pin.
I'd guess (& HOPE) that you can get a bunch of bushings to rehab those joints - well, you've probably already DONE it by now ?
Please update ?
2025 Pabreak Auger Bits and Plate Skid Steer Attachment (A61567)
2025 Pabreak Auger...
2018 Merlo TF30.9 115 (A62177)
2018 Merlo TF30.9...
2008 Regal 2565 Express Cruiser Boat with 30ft T/A Continental Boat Trailer (A61569)
2008 Regal 2565...
Deere 310SK (A57148)
Cummins 6-Cylinder Diesel Engine with Transmission (A61568)
Cummins 6-Cylinder...
(INOP) 2012 INTERNATIONAL DURASTAR 4300 SBA TRUCK (A59823)
(INOP) 2012...
