Woods Spindle 4116 rebuild
/ Woods Spindle 4116 rebuild #1
YODIE
Pequot Lakes, MN
Yanmar YM1700, 1951 Farmall Super C
Trying to rebuild my Woods mower deck 59HC for my old Farmall Super C
I can not figure out how to pull the spindle apart as the diagram shows. Do I need a press to take it apart?
/ Woods Spindle 4116 rebuild #2
I would say yes you need a press. Does the pulley on top have a tapered bushing holding it on? If so remove it and everything presses out the bottom of the housing.
yea, the pulley is held on by a tapered Bushing as you described. I have that off and the spindles on the work bench. unfortunately I dont own a press :-( I was hoping I could just hit them a few times and they would come apart. but no dice.
/ Woods Spindle 4116 rebuild #4
Every Woods spindle I've ever messed with was tight, needed a press. Know anybody who has one you can take it to?
I am sure i can find a place to take it. Will it need to be pressed back on?
/ Woods Spindle 4116 rebuild #6
You may get lucky and be able to tap it back together with a hammer and wooden block but be prepared to press it back on so you don't mess anything up.
Ok.. thanks so much for your advise.
/ Woods Spindle 4116 rebuild #8
You are very welcome, good luck with your rebuild.
Just wanted to follow up on this for others in future. This is possible without a press. Drive #4 roll pin out and a bfh and it will come apart. I used a piece of pipe to drive bearings on and off. Honestly the worst part was driving the old races out. For some reason they didn't want to move.
Thanks again for everyones help.
/ Woods Spindle 4116 rebuild #10
Yodie - just wondering did you replace all bearings and seals in each spindle? OEM Woods parts or aftermarket generic?
What was parts cost per spindle. Thanks
I did buy after market. I found some on ebay. They worked great. It was like $45 a spindle.
New Landhonor Skid Steer Utility Hitch Adapter (A62679)
New Landhonor Skid...
CATERPILLAR D9T CRAWLER DOZER (A64279)
CATERPILLAR D9T...
24ft. Folding Harrow (A65640)
24ft. Folding...
Danuser SM40 Skid Steer Pile Hammer (A65640)
Danuser SM40 Skid...
2021 CATERPILLAR 289D3 SKID STEER (A65053)
2021 CATERPILLAR...
2018 BOBCAT E50 EXCAVATOR (A65053)
2018 BOBCAT E50...
