Woods RM59
/ Woods RM59 #1
Alan W.
Kentucky
Kubota L3650 & Bobcat 763G & Craftsman DGS6500
Ive been looking for a cheap RFM and I found this. It needs an idler bearing which Ive ordered.
I have a three point hookup to replace the quick hitch in it. Not for my lawn but for some areas
that I want looking better than the bush hog does and is a little rough for the lawn tractor.
/ Woods RM59 #2
Doesn't look bad to me. A little repair here and there , sandblasting, paint and it will look like new..
And if you got it for a good price, well worth it.
/ Woods RM59 #3
Use only name brand woods belt $80- $100 other ones do not work. The on line places trick you into thinking they are woods! Go to a dealer. The wheels are expensive 4 would be better. Each spindle has a grease fitting. The on line manual has a roughting belt diagram. It has been a dependable implement. It can be used behind a 8 or 9 n ford with chains to hold the lift at the correct height.
/ Woods RM59
Ive got $75 in it plus a bearing. Ive heard about the aftermarket belt problems. This one still looks good but time will tell.
I had a Caroni RFM that the wheels were high. I replaced them with HF pneumatics, a world of difference on deck bounce.
/ Woods RM59 #5
You can use an aftermarket belt if you choose carefully. A&I sells high quality belts and they cross reference many OEM belt part numbers. I used to sell their equivalent belt to fit a Woods RM990 for about 2/3 the Woods price. Used one on my own mower and never had a complaint from a customer. Place I worked at was a Woods dealer. Their belts are great quality but stupid money.
/ Woods RM59 #6
I also never had any luck with any brand belt but Woods, on mine too...
SR
2020 JOHN DEERE 770G MOTORGRADER (A63276)
2020 JOHN DEERE...
2016 Ford Explorer AWD SUV (A64557)
2016 Ford Explorer...
Bell 500 Gallon Saddle Tank (A64119)
Bell 500 Gallon...
300# SPIN SPREADER, 3PT (A64278)
300# SPIN...
2026 SDLANCH SDLMG1220F Galvanized Metal Livestock Shed (A64194)
2026 SDLANCH...
Craftsman 16in Variable Speed Scroll Saw (A64553)
Craftsman 16in...
