Woods BrushBull 60
/ Woods BrushBull 60 #1
78westfalia
I'm thinking about sharpening the blades on my Woods BrushBull 60. Is there a way to make sure that everything is balanced? Or is it not important?
/ Woods BrushBull 60 #2
Make sure to grind off equal amounts to the best of your ability. Then drive a nail straight into a wall. Make sure it is straight in and not angled. Hang your blade on it. Situate it parallel to ground. If it falls on one end, remove a little from that side. Recheck and grind until it hangs evenly.
/ Woods BrushBull 60 #3
As long as you don't get completely carried away on one blade you will be fine. Brush hog blades aren't as critical as finish mowers are.
The problem is that the blade is attached only at one end. Each blade would not be balanced separately, but rather as a whole unit (both blades).
/ Woods BrushBull 60 #5
Weigh each blade then so they are the same.
Duh! I should have thought of that! Thanks.
/ Woods BrushBull 60 #7
LOL... Yeah sometimes solutions are so simple they are hard to see. /forums/images/graemlins/grin.gif
Takeuchi TB225 (A62177)
Takeuchi TB225...
2018 Ram 1500 Reefer Meal Delivery Truck (A61573)
2018 Ram 1500...
2019 Kia Optima Sedan (A61574)
2019 Kia Optima...
1042 (A60430)
1042 (A60430)
2020 Deere 544L (A60462)
2020 Deere 544L...
2017 Freightliner M2 106 AWD Terex Hi-Ranger 5TC55 55ft. Insulated Material Handling Bucket Truck (A60460)
2017 Freightliner...
