Box Scraper Woods Box Scraper Question
/ Woods Box Scraper Question #1
TDVT
NEK Vermont
'49 Ford 8N & '08 Kubota L3400
I just picked up a used Woods/Gill SR65 box scraper & it is the smallest of the SR models which have "retractable" scarifiers. Basically the beam the scarifiers mount on pivots 90d so the shanks are parallel to the ground when they are retracted.
There are only two height settings (notches) for the shanks & when the beam pivots, the shanks are either all the way down or completely retracted, no in between. What I've found so far is that even on the higher setting, the teeth are probably 6" below the blade, far more than I would like for our driveway & the rocky soil around here.
I was wondering if anyone else has this model & might offer any tips for using this model box. There is no info on set-up in the manual. I may add some extra notches to the shanks for a lighter cut but thought I'd ask first as I may be missing something.
Thanks, TD
1996 CATERPILLAR D6E CRAWLER DOZER (A62129)
1996 CATERPILLAR...
2022 Mack Anthem T/A Wet Kit Day Cab Truck Tractor (A61568)
2022 Mack Anthem...
AIR VENT INC (A62131)
2014 Ford Focus Hatchback (A61569)
2014 Ford Focus...
2004 MCI D4500 Bus, VIN # 1M8PDMPA44P056241 (A61165)
2004 MCI D4500...
2006 ISUZU NPR 4X2 BOX TRUCK (A59908)
2006 ISUZU NPR 4X2...
