WKY Horse Barn
   / WKY Horse Barn #1
TwinWillows
WKY near Bardwell
NH TC40DA
This is my first post other than asking a few tractor questions. It's been about a year since we started our barn & we're finally at the point where we could start putting roofing & siding up on the north side. I hope you find the barn project interesting. W/o a doubt it's the largest building project I've ever tackled! I'll post some other photos as I gather them up.
   / WKY Horse Barn
Here's the photo I ment to post.
   / WKY Horse Barn
This is a view in the hall of the barn showing the bottom of the loft & the brackets I made to transfer the weight of the loft into the 6x6 posts. The barn is 48 ft long x 40 ft wide. The height to the lowest eave is 12 ft with a full 12 ft of clearence under the main loft.
   / WKY Horse Barn #4
Very nice barn, keep us posted on your progress.
   / WKY Horse Barn
Here's a view inside looking up @ the North west corner.
   / WKY Horse Barn
The brackets on both sides are made from 4x6 pressur etreated posts cut to 12" long with a bevel cut on the bottom to make them blend in. They are gorilla glued to the 6x6 posts, bolted w/2ea 5/8 galv bolts. Additionally, the back sides of each bracket and the mating surface of each post are drilled in 4 places 1" deep to receive a 2" long piece of 3/4" Stainless steel pipe. The pipe provides additional surface to distribute the shear force into the post. I fugure with all this reinforcing the main loft won't go any where when we load it w/hay next spring. Simpson hurricane strapping was used to hold the TJI beams tight to the post durring installation. That's heavy stuff, I cut it & bent all the corners in my vise in order to get it to fit up neatly.
   / WKY Horse Barn
Bill,
Thanks for the kind words. Still have a long way to go but it sure feels good to be this far.
   / WKY Horse Barn
Here's a shot of the soffit metal going into place.
   / WKY Horse Barn
Finished the siding on the north wall.
2019 KUBOTA SVL95-2S SKID STEER (A52705)
2019 KUBOTA...
2018 Ford Fusion Hybrid Sedan (A53424)
2018 Ford Fusion...
JOHN DEERE 8R310 TRACTOR (A54756)
JOHN DEERE 8R310...
2018  FREIGHTLINER M2 26FT NON CDL BOX TRUCK (A52576)
2018 FREIGHTLINER...
2016 Freightliner M2106 Cab Chassis (A52377)
2016 Freightliner...
JOHN DEERE 2150 TRACTOR (A51406)
JOHN DEERE 2150...
