WKY Horse Barn
   / WKY Horse Barn #1
TwinWillows
WKY near Bardwell
NH TC40DA
This is my first post other than asking a few tractor questions. It's been about a year since we started our barn & we're finally at the point where we could start putting roofing & siding up on the north side. I hope you find the barn project interesting. W/o a doubt it's the largest building project I've ever tackled! I'll post some other photos as I gather them up.
   / WKY Horse Barn
Here's the photo I ment to post.
   / WKY Horse Barn
This is a view in the hall of the barn showing the bottom of the loft & the brackets I made to transfer the weight of the loft into the 6x6 posts. The barn is 48 ft long x 40 ft wide. The height to the lowest eave is 12 ft with a full 12 ft of clearence under the main loft.
   / WKY Horse Barn #4
Very nice barn, keep us posted on your progress.
   / WKY Horse Barn
Here's a view inside looking up @ the North west corner.
   / WKY Horse Barn
The brackets on both sides are made from 4x6 pressur etreated posts cut to 12" long with a bevel cut on the bottom to make them blend in. They are gorilla glued to the 6x6 posts, bolted w/2ea 5/8 galv bolts. Additionally, the back sides of each bracket and the mating surface of each post are drilled in 4 places 1" deep to receive a 2" long piece of 3/4" Stainless steel pipe. The pipe provides additional surface to distribute the shear force into the post. I fugure with all this reinforcing the main loft won't go any where when we load it w/hay next spring. Simpson hurricane strapping was used to hold the TJI beams tight to the post durring installation. That's heavy stuff, I cut it & bent all the corners in my vise in order to get it to fit up neatly.
   / WKY Horse Barn
Bill,
Thanks for the kind words. Still have a long way to go but it sure feels good to be this far.
   / WKY Horse Barn
Here's a shot of the soffit metal going into place.
   / WKY Horse Barn
Finished the siding on the north wall.
KENWORTH T/A DAY CAB ROAD TRACTOR (A52706)
KENWORTH T/A DAY...
2007 JLG 600S TELESCOPIC MANLIFT (A52705)
2007 JLG 600S...
2021 JOHN DEERE HX14 LOT NUMBER 14 (A53084)
2021 JOHN DEERE...
2017 Yamaha VX1050B Deluxe Jetski (A50324)
2017 Yamaha...
12-Wheel Pneumatic Pull-Behind Asphalt Compactor (A52377)
12-Wheel Pneumatic...
2021 MDB TF150R 84" HYD MULCHING HEAD (A51406)
2021 MDB TF150R...
