winterizing
   / winterizing #1
fosterlot
maine
kubota
In order to store a tractor during the winter in an unheated pole building, what are the things I should know?
   / winterizing #2
I'd get the tires off the dirt if you are storing it - plastic, wood, etc to keep them from drying out over time. You want ventilation - stops the buildup of moisture from condensation which leads to rust. Be liberal with oil. Don't cover it. Some tractors want you to block the clutch. I always using mine- so I really don't know more than that. In the manual if you have it.
   / winterizing #4
if it's a gear / clutch tractor...you should use a block of wood etc. to hold the clutch peddle in the depressed position...to prevent it from sticking to the plate...My tractor came with said block of wood from K_ubota for this purpose...
   / winterizing
How about liquid cooled tractors. Should I drain fluids when I know weather will be really cold (-25 F)?
   / winterizing
Thanks for the helpful info. I am a new convert to the joy of tractors!
   / winterizing #7
Welcome to TractorByNet!
I moved your thread to the Owning & Operating forum. :)
2019 Club Car Carryall 1700 4x4 Diesel Utility Cart (A51691)
2019 Club Car...
2004 Ford F-550 Miller 301 Wrecker Truck (A51692)
2004 Ford F-550...
2007 International 4300 Cab and Chassis Truck (A51692)
2007 International...
UNUSED White Metal Roof Panels (A53117)
UNUSED White Metal...
UNVERFERTH 210 (A53084)
UNVERFERTH 210...
2017 GMC Sierra 1500 Elevation Crew Cab Pickup Truck (A51692)
2017 GMC Sierra...
