wind generator
/ wind generator #51
I don't mean to steal the thread, so if there is enough interest we can spin off into another one.
The walls of my house are 6" sips and the roof is 8" sips. The foundation is poured concrete with 2 inches of solid insulation on the exterior. No air to air exchange as of yet. The woodstove produces more heat than we can use unless it is below zero and no sun. The exchanger cost about $2400 plus the electricity to run it. We just leave one window open in each room a little bit for air exchange. Currently with wood heat we are at 40% humidity in the home, it will drop to about 32% in march.
Jim
/ wind generator #52
you can get a pretty simple heat exchange unit under $1000 that uses a shared 6" hole for intake/exhaust and just needs a wall grate for intake and a second one for exhaust - no major ductwork. If you're interested, PM me and I'll try to get info on it - I think it's a Broan.
/ wind generator #53
...The LED's are awesome. The only downside is that they don't melt the snow! ...
My wife and I noticed that last winter, when, driving to work during a snow storm none of the stop lights were visible.... the snow stuck to them and they had been changed to LED bulbs over the summer.... kind of a safety hazard if you ask me.
/ wind generator #54
My experience. We live totally off-grid.
First we built a 640 sqft cabin as a place to live and store stuff while we built the real house. For power, I built a Solar, PV system with inverter and battery storage. Our 6 panel system was 730 watts and would average about 3kw/day. We do have wind and at least 4 neighbors have wind generators of various types. I had hoped that adding a 400 watt AirX would give me a little plus up, especially at night or during other periods of less sunshine. For the cost of the AirX, tower, wiring, I could have added 2 more PV (250watt) and been reasonable assured of generating another 1kw/day. My AirX never came close to producing that. In fact, it's production was never even measurable on my existing equipment in spite of the visibly glowing LED I could see at night. This was disappointing for 2 reasons: #1 - I knew what I'd lost by chosing the AirX instead of 2 PV, but even moreso, #2 - I had hoped a wind generator would be a good complement/backup for the big house. Someday, when I take that system off line, I'll have to find a new home for AirX or suck up the loss. The Pvs I can add to my other system.
The house we built is also a SIP system and we have R20, both walls (ProTec) and roof (Galvamet). Not a great concern as we have no HVAC, neither heat nor cooling. We do have reasoned cross ventilation, ceiling fans, and propane fireplaces. Nearly all lights are cfl or florescent. Most of the cfl are 9w. Many we bought on sale, all bought as original equipment, not replacements. So the ceiling fan fixtures have 4X9=36w vs 4x60=240w. We also practice lots of conservation, such as power strips and unplugging stuff.
The power system for the big house is 36 PV, 4.5 kw, inverters and battery storage. We currently use about 13kw/day, but know that will increase once everything is installed and we start up the pool. For backup, I added a 24kw diesel genset, which I've run 100.8 hrs over the last 18 months. Would prefer RE backup. Still looking at hydro option, but that's a different story. Had my above experience with wind been positive, I would consider it. Given that it appears a suitable wind generator w/tower would run about $20K initially, it doesn't seem feasible. Even if red diesel stays near the $5/gal level, that's 4000 gallons - 10 years worth at 1gal/day.
JMHO, but don't see grid tied wind combo as having much value, especially if there is no battery backup.
David
/ wind generator #55
I bought a Skystream 3.8 on a 70' tower. Installation was completed a month ago. It is grid-tied, so when the power is off at the pole, the turbine quits turning.
Butch, please provide details!!! Wind speed, and pictures!!!!!!!!!!!!!!!!!!
Bob
/ wind generator #56
David
David, do you have any knowledge of your neighbors systems and results? As I said in my post on my experiance, we had a system that we installed that turned out to be rather problematic. My friend that owned the business did the best that he could to satisfy his customers with that system. The concept seemed solid but overall we felt that there were to many off the shelf components that just did not measure up. He certainly got stung as did the customers.
Your system did not perform to your expectations. Don't beat yourself up and thanks for sharing the info.
My point is, be it PV cells, wind, whatever, there are a lot of people trying to cash in on energy saving devices. PT is alive and well. Be very careful with your money.
/ wind generator #57
One of the factors anyone needs to consider when contemplating either a PV or wind system is that the sales people may say it's a 10KW system, but in reality it's only a 10KW system under the best conditions--when it's noon in the summer for the PV system or at the designed wind speed for the wind system. All other times, they produce something less, often a lot less or none at all. So how long does the sun stay at high noon, or what percentage of the time does the wind blow at the optimum speed?
OTOH, here is a low tech, low investment idea to consider. You put up a modest tower, & install a second hand generator. Wire that to coils in your furnace return air duct. When it's cold and the wind is blowing, turn on your fan in your forced air system to circulate the air and run it across the coils for a little low cost (you have to pay for the power to the blower) heat. It's not on the grid, it's not electrically tied to any electrical stuff in your house, it just goes from the generator to the coils, so there is no fancy equipment to make it fit into the grid. In the summer, tie the propeller down. No, I haven't tried it; it's just a pipe dream, but it just might save a few bucks and a little carbon. And no, it's not going to make a huge difference, but the ROI may be a lot better than the fancy systems.
/ wind generator #58
Were in a river valley so we would need a very tall tower. At work we have a crew that builds towers for wireless internet - the cost of a 125' tower including the base is usually around $80K. Our province is now using net metering so I could put back into the grid at the same cost as taking out of the grid. I still suspect the payback is over 25 years. Point well taken that maybe the payback is not the only measure.
We live beside a major river. I have always wondered if there is any lower generators that can run from hydro power - anyone know of anything? I'm sure the enviromental commands are huge when considering hydro but maybe there is a fish friendly units now made!
Garth
/ wind generator #59
If you really really really stop and think for a long while, you will see where some smarts can reduce energy waste. Here are some of my hair brained ideas, in no order
- Outlaw all vehicle colors other than glare white or polished metallic. Then less heat will be absorbed and less global warming
- Outlaw all home / building colors other than glare white or polished metallic for the same reasons.
- Mandate pavement color a bright white for the same reasons.
- Mandate a doubling or tripling of insulation in homes
- Mandate energy standards for appliances. Most people don't know that TV's are energy users about equal to a side by side fridge/freezer when they are OFF. True.
- Give tax breaks ( or tax penalties) for set back thermostats that are connected and programmed by satellite the way new clocks are. The government could easily mandate this and force the utilities to double or even 10x your rate if you didn't convert to a government programmed setback thermostat.
- Give tax breaks for riding a bike to work.
- Give tax breaks for moving closer to work to minimize or eliminate vehicular commutes
These are not hair-brained.
Many of your ideas have been espoused by the Green Building movement, and in a few areas, municipalities require all new construction having to attain a minimum rating issued by the US Green Building Council. So, many of your ideas have already become law!
USGBC: About USGBC
/ wind generator #60
Hi Doc,
I will post pictures as soon as I can. I expect to get a bill from my power company for my first full month with the turbine in operation. December, though, was a highly variable month for wind speed.
Butch
New Holland WorkMaster 37 (A53317)
New Holland...
2020 DRAGON 150BBL ALUMINUM (A58214)
2020 DRAGON 150BBL...
2013 PETERBILT 367 DAYCAB (A58214)
2013 PETERBILT 367...
2016 Ford Explorer AWD SUV (A59231)
2016 Ford Explorer...
JLG E300AJ (A60462)
JLG E300AJ (A60462)
2014 Ford F-150 4x4 Ext. Cab Pickup Truck (A59230)
2014 Ford F-150...
