Willys cj3b
/ Willys cj3b #41
Here are some picture of panels I built from sheets of steel. I made plywood forms and clamped the steel to it and bent the edges around the plywood to make the shapes. The top edge was bent all the way around into a u shape and I inserted a piece of 1/2" square tube in it for additional strength. I will try to find pictures of building the panels this week.
Wow!
Thanks for posting, my first vehicle was a Jeep CJ-5 w/304 V8.
/ Willys cj3b
Got it running tonight. Runs pretty well. New problem now, only drove it about 10 feet and something is locking up either in the transfer case or transmission. Rolls fine in neutral but kills engine when I try to drive (locks up drive wheels).
/ Willys cj3b #43
I had that happen once in 4WD only. Loose ring gear in front.
Bruce
/ Willys cj3b
dropped the transmission and transfer case yesterday afternoon. Both are in need of complete rebuilds. t-case will only turn about 1/4 turn before locking up. guess I found my problem
/ Willys cj3b #45
Good you caught it before catastrophic failure... with a little luck it will be bearings and bushings?
/ Willys cj3b
Well it is the transfer case for sure. I have a good friend that owns a transmission shop and he is going to rebuild both trans and transfer case for me in exchange for some tractor work. He needs some asphalt millings moved and graded at his house on the driveway. You knew the tractor had to fit in here somehow. Actually I can't imagine doing all this without it. I've used it to move the jeep around, remove and install the body by myself at least a dozen times, pull the engine, and just this morning I used it to load the transmission and transfer case in the back of the truck.
/ Willys cj3b #47
wow that's a nice job! I like the fact that you restored it to original looks without any mods
/ Willys cj3b
Actually they are 16 inch rams off of an older Willys. Tires are 6.50x16
/ Willys cj3b
Still waiting on the transmission so working on other parts. Finished sewing passenger seat cushions and installed and installed the hood. Had to make some adjustments to make everything fit correctly.
/ Willys cj3b
Finally got it moving under its own power!!!
What a good feeling. Have lots of little things to make it "done".
1998 Ferguson 46B Compactor / Roller (A62613)
1998 Ferguson 46B...
2005 SBX-5 Box Blade Tractor Attachment (A61572)
2005 SBX-5 Box...
Steel Blasting Shed (A62679)
Steel Blasting...
2437 (A65640)
2437 (A65640)
2008 Kawasaki ZX1000 Motorcycle, VIN # JKAZXCE1X8A013733 (A65563)
2008 Kawasaki...
2022 EZ-GO ELITE...
