Will this work? Smoothing bumpy lawn
/ Will this work? Smoothing bumpy lawn #21
"You need to consider, it could be where the bodies are burried. As decay takes place the dimples in the ground become more pronounced.
You may want to dig a few test holes in the berm to see if there is any debris buried. My excavation contractor built a berm in my backyard with tree and brush debris collected from the property. It also has the most lush grass, although settling has not been a problem (18 years). Buried debris could complicate your leveling goal!
/ Will this work? Smoothing bumpy lawn #22
The dark topsoil is richer and better to support plant growth. If there's too much clay in the soil, it can become compacted and hard to grow anything in.
How large is the area to be re-worked? Large enough to order a truckload? Around here, we can make one phone call and have a load delivered to the site. Are there any sand and gravel operations or nurseries that also sell topsoil?
/ Will this work? Smoothing bumpy lawn #23
others already mentioned it, but i would be prepared about other debris in the mound.
as far as type of grass you have and want to keep. get a shovel out get a few descent size samples and take to a nursery. ((calling before hand of course to make sure they have someone knowledgeable. i would assume all, but maybe not)) to get type of a grass seed.
if you strip the sod that you do not want. you can get a *of course i can not remember the name of it* it is a small shovel like tool that cuts out approx 3" diameter circle out of grass ((plug)) that you can then move to area you need to grass to grow.
you can use a spade or round headed shovel to do above, but it requires extra work. vs just putting the tool down steping on it. and lifting the plug up and out and moving it to the area you want.
the area you want grass to grow. ya space the plugs a inch or 2 apart. and over the next year or 2. just let the grass spread out like it would normally.
as far as holes left in rest of your yard were you removed the bigger size plugs. refill back in with top soil or perhaps "aerate your yard" to get all the little 1/2" size plugs to use to fill in the bigger size holes. and let the grass grow back into the holes over the next year or 2.
i don't think you will be happy with final grade, of just using the FEL bucket. it can leave some pretty bumpy lawn. and would look at a tiller, or plow,disc,harrow. or some combination of them. so you can get a nice fluffy dirt / loose dirt on top. and get everything nice and smooth.
if this was a pasture ya sure FEL and be done with it.
but if the mound is bugging you, and some smaller ruts are as well. then at least in my experience FEL was not simply enough for final grade. just left an over all un-evenness in spots.
429860 (A61166)
429860 (A61166)
2015 Ford Taurus AWD Sedan (A61574)
2015 Ford Taurus...
2007 PETERBILT 340 ROLL OFF TRUCK (A59909)
2007 PETERBILT 340...
2018 Chevrolet Silverado1500 Crew Cab Pickup Truck (A61573)
2018 Chevrolet...
2016 WESTERN STAR 5700 6X4 T/A SLEEPER TRUCK TRACTOR (A59912)
2016 WESTERN STAR...
2002 Ford Ranger Pickup Truck (A61573)
2002 Ford Ranger...
