Will this fit
/ Will this fit #1
coupman35
Northen Ontario
Now a L4060 had B2650
Am looking for turf tire for my b2650.Founf this are they to big CARLISLE 27X8.50-15NHS - (2) TITAN 41X14.00-20NHS and are they a good mach set for my tractor.
/ Will this fit #2
What tires do you have now?
You need the same size tire OEM specs or you will screw up your 4wd ratios
/ Will this fit #3
Need to match the same ratio for the rolling circumference as the tires you are replacing. Wheels must but be designed to accept section width of tire. Every tire has a recommended rim width published by tire manufacturer. If mechanical assist, FWD, all four tires must be in same ratio.
A knowledgeable AG tire dealer would perform the computations for you.
/ Will this fit #4
Good advise above.
If you change from R-1s or R-4s to turfs, you must change all 4 rims and tires to avoid gearing issues. Use only the Kubota recommended tire sizes.
Be advised that not all tire options are compatible with all MMMs and/or tire chains.
SDT
/ Will this fit
fhis is what Kubota said to use b2650 Kubota tractor size 13.6-16 rear and 24x8.5 14
/ Will this fit #6
Coupman,
I bought new shoes for my ford one year ago from walmart, free shipping. Carlisle turf tires, 4 ply, 13.6 x 16 $250 each.
Purchased replacement rims, used in VG condition from Weaver compact tractor parts in PA. $200/ea. Shipping extra, wheels were boxed.
/ Will this fit #7
These tires sound like ones for a Grand L tractor and not a B size tractor.
Stock size are 24x8.5-14 for front and 13.6-16 on the rear.
Wholegoods in US is $181 for the fronts and $423 for the rear. This price includes tire and wheel assembly ready to bolt onto your tractor. Order code is ABR8742 and ABR8744 (F&R respectively).
Please note my listing isn't the latest and info and prices can change.
/ Will this fit
The only thing am in Canada .Shipping will be crazy on some thing like that >Am looking for a Canadian dealer
/ Will this fit
OK I found a set of turf tire 24x8.5-14 they are one inch bigger then the one I have on 23x8.5-14.Will this work are it not ok because of the size
/ Will this fit #10
You can buy a complete set of front and rears mounted on new wheels for under $400 directly from Kubota. You might try calling your dealer. The cost from Kubota might surprise you.
/ Will this fit
That in the USA I got a price last week just the back one on rim 550.00 Plus tax
2016 BOBCAT T650 SKID STEER (A62129)
2016 BOBCAT T650...
2006 Genie Z45/25J Articulated Boom Lift (A64047)
2006 Genie Z45/25J...
UNUSED JCT 4 PRONG BALE SPEAR (A62131)
UNUSED JCT 4 PRONG...
John Deere S350 (A60462)
John Deere S350...
40' CONTAINER (A62131)
2023 Kubota Z412KW Zero-Turn Mower with 3-Bag Bagger System (A63118)
2023 Kubota Z412KW...
