Will this fit
/ Will this fit #1
coupman35
Northen Ontario
Now a L4060 had B2650
Am looking for turf tire for my b2650.Founf this are they to big CARLISLE 27X8.50-15NHS - (2) TITAN 41X14.00-20NHS and are they a good mach set for my tractor.
/ Will this fit #2
What tires do you have now?
You need the same size tire OEM specs or you will screw up your 4wd ratios
/ Will this fit #3
Need to match the same ratio for the rolling circumference as the tires you are replacing. Wheels must but be designed to accept section width of tire. Every tire has a recommended rim width published by tire manufacturer. If mechanical assist, FWD, all four tires must be in same ratio.
A knowledgeable AG tire dealer would perform the computations for you.
/ Will this fit #4
Good advise above.
If you change from R-1s or R-4s to turfs, you must change all 4 rims and tires to avoid gearing issues. Use only the Kubota recommended tire sizes.
Be advised that not all tire options are compatible with all MMMs and/or tire chains.
SDT
/ Will this fit
fhis is what Kubota said to use b2650 Kubota tractor size 13.6-16 rear and 24x8.5 14
/ Will this fit #6
Coupman,
I bought new shoes for my ford one year ago from walmart, free shipping. Carlisle turf tires, 4 ply, 13.6 x 16 $250 each.
Purchased replacement rims, used in VG condition from Weaver compact tractor parts in PA. $200/ea. Shipping extra, wheels were boxed.
/ Will this fit #7
These tires sound like ones for a Grand L tractor and not a B size tractor.
Stock size are 24x8.5-14 for front and 13.6-16 on the rear.
Wholegoods in US is $181 for the fronts and $423 for the rear. This price includes tire and wheel assembly ready to bolt onto your tractor. Order code is ABR8742 and ABR8744 (F&R respectively).
Please note my listing isn't the latest and info and prices can change.
/ Will this fit
The only thing am in Canada .Shipping will be crazy on some thing like that >Am looking for a Canadian dealer
/ Will this fit
OK I found a set of turf tire 24x8.5-14 they are one inch bigger then the one I have on 23x8.5-14.Will this work are it not ok because of the size
/ Will this fit #10
You can buy a complete set of front and rears mounted on new wheels for under $400 directly from Kubota. You might try calling your dealer. The cost from Kubota might surprise you.
/ Will this fit
That in the USA I got a price last week just the back one on rim 550.00 Plus tax
2002 Freightliner FS65 Bus, VIN # 4UZAAXAK92CJ75418 (A61165)
2002 Freightliner...
Wooden Three Headed Native American Statue (A61569)
Wooden Three...
UNUSED SDLANCH SDLE18P MINI EXCAVATOR (A62130)
UNUSED SDLANCH...
40ft High Cube Shipping Container (A61166)
40ft High Cube...
36 Gallon RV Septic Caddy (A61166)
36 Gallon RV...
25' SINGLE AXLE VEGETABLE TRAILER 5TH WHEEL (A62130)
25' SINGLE AXLE...
