Will it survive? Should I even try?
/ Will it survive? Should I even try? #1
Seamonster124
WA
BX1880
Pretty big but also lot of roots. I've transplanted pretty big evergreens with roughly 50% survival rate. This is the largest one so far. It's a western hemlock. I'm in the Seattle area and it's the start of our wet season so what you guys think?
/ Will it survive? Should I even try? #2
Good luck . . . :D make sure you have all air pockets gone.
/ Will it survive? Should I even try? #3
Nothing ventured nothing gained. I've seen trees planted that size, but generally more care is taken when digging to keep the soil on the root ball. Fill your hole with water until it turns to soup, so that the roots can suck it up. Let us know how the tree looks next year at this time. Good luck.
/ Will it survive? Should I even try? #5
Not familiar with that tree species, but thought they were supposed to be a hardy tree? Don't know, but that root ball looks pretty badly destroyed from my perspective. But I'm used to dealing with other tree species.
/ Will it survive? Should I even try? #6
Is that your rear tire creasing over the rim?
/ Will it survive? Should I even try? #8
I want to know if that shed is working it's way over the hill.....
/ Will it survive? Should I even try? #9
Normally trees that size, and larger, are replanted with the root ball intact and either balled or boxed. Around here stuff seems to defy the rules of nature though. I have seen trees over 2' caliper moved and survived. They were boxed in place and moved out of the hole with a big excavator, lay over and cover the bottom with plywood. Set up in reverse with tons of water and fertilizer. As has been mentioned, lots of water when planting. If you are planting in soil like over herein Kitsap; you will want a big hole and lots of organic bearing back-fill. Evergreen tree roots do not penetrate into clay or sandy soil very far; their roots spread out latterly.
I took out a big fir and a big cedar at one place I lived. Both over 3' caliper. Dug around and cut off the big roots that were not very deep. We literally skidded the stumps across the sand to get out of the hole with a little Taramite backhoe.
Ron
/ Will it survive? Should I even try? #10
Find out how/which branches to prune back. ie on pinus radiata you prune year 4 and older branches when transplanting, as the year 1,2, and 3 branches provide most off the photo synthesis.
You are also aiming to reduce the moisture stress on the tree while it grows new roots it.
Generally winter is the best time to transplant as the tree is either dormant, or growth has slowed right down over the cold period.
/ Will it survive? Should I even try? #11
The safety police are out in large numbers,be careful.
/ Will it survive? Should I even try? #12
Looks like most of roots are damage plus what you said,get rid of the trees plant new one.
/ Will it survive? Should I even try? #13
I wouldn’t hold my breath on the survival chances.
My tree guy tells me the rule of thumb is one foot of root ball for each inch of trunk diameter when transplanting trees.
Your results may vary.
B. John
/ Will it survive? Should I even try? #14
The tree or the shed?
/ Will it survive? Should I even try? #15
It has been said that the orientation of the tree should match where it was taken from - in other words it should be facing the same direction so that the sun comes up on the same side of the tree as it did where it began. No one has been able to get a tree to admit that this is important though.
/ Will it survive? Should I even try? #16
You are not hooking high on the ROPs to pull, are you?
The tree? It might live but would have to be staked up for a few years.
/ Will it survive? Should I even try? #18
And why is the tow strap hooked so high?
It looks like he took the suggestion on another thread to hook to the ROPS seriously.
2018 Ford F-150 4X4 (A62679)
2018 Ford F-150...
John Deere 3010 Tractor (A66408)
John Deere 3010...
2014 GULF STREAM TRAILMASTER (A65643)
2014 GULF STREAM...
2009 PROCO 130BBL (A65643)
2009 PROCO 130BBL...
New/Unused Wolverine 6 Way Dozer Blade (A65583)
New/Unused...
SET OF (4) PORT A POTTIES (A65643)
SET OF (4) PORT A...
