Will a ratchet rake ..........
/ Will a ratchet rake .......... #1
NTrotty
Texas
Kubota 2320
I have a kubota B2320, have many cedar stumps cut low to the ground, most cut 2 seasons ago, would a ratchet rake 48", on my loader pull those stumps up? They range from 3" to 6" maximum diameter.
Or just rent a stump grinder.
/ Will a ratchet rake .......... #2
I doubt it unless you're in a swamp. I'd dig them out with a backhoe or excavator, or if you could get traction you could try pulling them out with a chain on a truck.
Never underestimate roots.
/ Will a ratchet rake .......... #4
One inch Cedars, YES. Three to six inch Cedars, NO.
Rent the stump grinder.
/ Will a ratchet rake .......... #5
my wife hit a four inch ceader with a 68 buick and pushed the motor back 3 feet, hitting the front seat.
/ Will a ratchet rake .......... #6
Cedar trees have the most extensive and hardest to pull out root systems of any tree (maybe a thorn tree is comparable). You would need a backhoe to dig them out. Before I got my back hoe, I was using my LS P7010 with FEL to dig out a 8" diameter cedar. I had to dig a deep hole around it and use a chain to pull it out. It was all the 70 HP machine wanted to get it out and then had to pull some individual roots out. I wouldn't recommend tackling them with anything less than a back hoe. Never seen cedar grown in a swamp so I think you would be on a ridge and in hard ground so it isn't going to be easy.
/ Will a ratchet rake .......... #7
Rent the grinder, I have a 72 inch RR on my 45 hp Mahindra. I cut an area full of saplings 3 seasons ago.The saplings were mostly gum, pine and a few oaks. I still can't push the gums around (3- 6 inch). (everything else is pretty easy) . This past winter - I just used the boot method to remove all the rest of the pines - one good kick- and they would go flying.
I know the cedar would be even more difficult than the gums. I got my stumps old staked out and ready
for my stump grinder guy.
/ Will a ratchet rake .......... #8
Must be different than the cedars on my place. Up to 5" come out easily with the tree puller. :thumbsup:
This one was harder!
Here is the link on getting it out: http://www.tractorbynet.com/forums/attachments/277824-tree-puller.html#post3444397
/ Will a ratchet rake .......... #9
A a ratchet rake is too wide. You need a narrow stump bucket.
Or something like this on the 3 point.
/ Will a ratchet rake .......... #10
View attachment 334994 View attachment 334995 View attachment 334996
Agreed, the 4-5" cedar stumps around my place seem to pop up pretty easy after being cut at ground level, a 1" hole poked about 5" down in the centers, and left a while to die. First one I used the backhoe on, but it popped out so easy when repositioning the tractor I hit the others with the FEL edge and lifted as I moved forward popping them loose easily. A couple I had to take two stabs at to break them totally free, but it was the easiest method I found on mine considering I didn't need to change to the backhoe for each one, and the tractor didn't need turned around to have the FEL bucket near to roll them into (was a tight area so it was something to be considered).
OP: I also agree a rake isn't going to do it. A heavy duty box blade may.
Mower deck storage axles
Mower deck storage...
Takeuchi TB016 (A53317)
Takeuchi TB016...
Deere 310L (A53317)
Deere 310L (A53317)
Neckover GL24-2-7K Gooseneck Trailer  24ft Deck, Dual 7K Axles, 14K GVWR (A61307)
Neckover GL24-2-7K...
Box of Transport Ratchet Straps (A59230)
Box of Transport...
2017 KALMAR OTTAWA T2 4X2 SPOTTER TRUCK (A60430)
2017 KALMAR OTTAWA...
