Will a ratchet rake ..........
/ Will a ratchet rake .......... #11
Xfaxman:
For a tractor like my B3300SU/33-hp/1,900 pounds, do you think a narrow stump bucket on the FEL, or a Brush Boss on the 3-Pt. is the better tool?
Does your "Brush Boss" have rear hydraulic tilt?
Is the "Brush Boss" still in production? No web site for Harkness-Hayporter.
In principle, I like the idea of tree removal by a tool on robust 3-Pt. hitch, rather than the FEL.
/ Will a ratchet rake .......... #12
Xfaxman:
For a tractor like my B3300SU/33-hp/1,900 pounds, do you think a narrow stump bucket on the FEL, or a Brush Boss on the 3-Pt. is the better tool? I think the 3 point would have more lift.
Does your "Brush Boss" have rear hydraulic tilt? No.
Is the "Brush Boss" still in production? No web site for Harkness-Hayporter. I couldn't find anything when I looked earlier.
Do you have anything like this for your 3 point?
You can add a ripper tooth or a scarifier or something to grab a stump.
3 Shank Scarifier - OMNI Mfg LLC
/ Will a ratchet rake .......... #13
/ Will a ratchet rake .......... #14
After looking at the link I remember it did come with the hydraulic cylinder. I bought it at a farm auction about 10 years ago. I had the MF240D then, the 3 point lift was strong enough that I removed the foot and never used the cylinder.
I turned the Brush Boss around, in 4WD any cedar tree that I could run over, it would pull out. :D
/ Will a ratchet rake .......... #15
I have the ratchet rake..its a great to for some things but not stumps bigger than bush size. Today I used the digger ripper for the first time. I just got it a couple days ago. Now that does some good digging. I would use it for those stumps for sure.
/ Will a ratchet rake .......... #16
Thanks for the post, Have RR and been thinking of getting the Digger Ripper. Only question I have about it is how do you see what you are digging? Doesn't tractor and FEL block view?
/ Will a ratchet rake .......... #17
Its definitely harder to see what your doing compared to digging with just the bucket. Ill know more as I use it more but I think it will be something I can get a feel for. I tip the bucket down so I can see the front of the teeth, then stab it in and start digging. It certainly wont be as easy as a backhoe but I think for a small job it will be ok.
/ Will a ratchet rake .......... #18
Here are two photos of my Bucket Spade. Once you are familiar with it visibility is NOT an issue.
Case-IH 180 Magnum (A57148)
Case-IH 180 Magnum...
2017 DRAGON 150 BBL ALUMINUM VACUUM TRAILER (A60736)
2017 DRAGON 150...
SET OF (10) ACE CATTLE PANELS W/CONNECTION JOINTS (A60736)
SET OF (10) ACE...
2024 JOHN DEERE 325G SKID STEER (A62129)
2024 JOHN DEERE...
(APPROX. 20) 4' X...
Roll of 2-inch Vacuum Hose (A57454)
Roll of 2-inch...
