Width
/ Width #1
ffgoo
Strongly considering purchasing my first tractor although we have various vintage tractors on the property. looking at 3720 but unsure of width. When i look at the website it shows widths from 54 to 66 approx. Is this based off tire size or model is my first question? We have 7ft spacing between rows and looking to keep tractor and box scrapper at 60 inches or less. Am I ok with the 3720 or am I needing to go down to the 2000 series which means no cab?:mad:
/ Width #2
I "THINK" what they are referring to is tractors rear wheels can be adjusted to 3 different widths by the way you mount and flip the rims! Check with your dealer he should be able to tell you the 3 different measurements! :thumbsup:
/ Width #3
Dimensions
NOTE: Height and width dimensions can vary due to dimensional growth of tires.
Wheelbase. . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 1.7 m (68 in.)
Overall Length w/ 3-Point Hitch. . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 3.1 m (120.2 in.)
Overall Width w/ R1 Tires (Minimum) . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 1.3 m (52.4 in.)
Overall Width w/ R1 Tires (Maximum) . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 1.7 m (68.4 in.)
Overall Width w/ R3 Tires (Minimum) . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 1.4 m (53.9 in.)
Overall Width w/ R3 Tires (Maximum) . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 1.5 m (59.1 in.)
Overall Width w/ 43 x 16.00-20 R4 Tires (Minimum) . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 1.5 m (58.1 in.)
Overall Width w/ 43 x 16.00-20 R4 Tires (Maximum) . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 1.5 m (59.7 in.)
Overall Width w/ 15.00-19.5 R4 Tires (Minimum) . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 1.4 m (57.3 in.)
Overall Width w/ 15.00-19.5 R4 Tires (Maximum) . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 1.5 m (58.9 in.)
Overall Width w/ Golf Tires (Minimum). . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 1.5 m (59.5 in.)
Overall Width w/ Golf Tires (Maximum) . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 1.6 m (64.7 in.)
Inside Width w/ R1 Tires (Minimum) . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 1.03 m (40.6 in.)
Inside Width w/ R1 Tires (Maximum) . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 1.4 m (56.6 in.)
Inside Width w/ R3 Tires (Minimum) . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 1.02 m (40.4 in.)
Inside Width w/ R3 Tires (Maximum) . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 1.2 m (45.6 in.)
Inside Width w/ 43 x 16.00-20 R4 Tires (Minimum) . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 1.1 m (42 in.)
Inside Width w/ 43 x 16.00-20 R4 Tires (Maximum) . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 1.1 m (43.7 in.)
Inside Width w/ Golf Tires (Minimum) . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 1.02 m (40.3 in.)
Inside Width w/ Golf Tires (Maximum) . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 1.2 m (45.5 in.)
Inside Width w/ 15.00-19.5 R4 Tires (Minimum) . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 1.1 m (42 in.)
Inside Width w/ 15.00-19.5 R4 Tires (Maximum) . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 1.2 m (43.7 in.)
Height From Ground (Tractor without cab, with standard R1 tires)
To Top of Hood . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 1.4 m (57 in.)
To Top of Folding ROPS . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 2.4 m (93.3 in.)
Height From Ground (Tractor with Cab, R3 tires)
To Top of Cab . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 2.3 m (89.4 in.)
/ Width
Beltzington....thank you!
As in (Dumb and Dumber) "So your telling me there's a chance?!" :laughing:
So depending on tires I choose and how I want to set I can get as skinny as the minimum widths and push them out as wide as the Maximum width. Is this for stability, wider being better or more stable? Thanks again
/ Width #5
It's manly for stability! On most 4 wheel drive models the frt. wheels cannot be adjusted, so you are stuck with the way they come. On 2 wheel drive the frt. wheel frames are usually adjustable! I don't do truck farming so I don't know which models that do or don't have adjustable frt. frames.
2023 John Deere 8R 370 Tractor (A63109)
2023 John Deere 8R...
2005 Great Dane Dry Van Trailer, VIN # 1GRAA56185K270688 (A61165)
2005 Great Dane...
2018 INTERNATIONAL RH613 TANDEM AXLE DAY CAB (A59575)
2018 INTERNATIONAL...
FRESHLY REFURBISHED! 2016 KBH Fertilizer Tender Trailer - Isuzu Diesel (A63118)
FRESHLY...
New/Unused Quick Attach Rock Hammer (A61166)
New/Unused Quick...
New/Unused Landhonor 72in Rock Grapple (A61166)
New/Unused...
