Wider tires on front of 2WD
   / Wider tires on front of 2WD #11
I use wider tires on my MF 135 that I use to feed round bales. It does help with flotation but that means it tends to skate more on turning. The big problem with wider tires is the extra leverage it can assert on the spindles. Bigger diameter is a better way to solve the problem.
Rob
   / Wider tires on front of 2WD #13
Rob
Larger diameter is not going to increase flotation, they will just let you bog deeper before you start to drag the frame. Larger tires carry more load, float better and as for skidding during turning, that is what steering brakes are for.
   / Wider tires on front of 2WD #14
Using the brakes does not work when the differential is locked. Larger diameter keep rolling much longer than small wide tires. The bales I make are about 1000lb FWIW.
Rob
LONG 445 TRACTOR (A51243)
LONG 445 TRACTOR...
2023 PETERBILT 579 TANDEM AXLE SLEEPER (A51222)
2023 PETERBILT 579...
2017 Caterpillar 259D Two Speed Compact Track Loader Skid Steer (A50322)
2017 Caterpillar...
2025 Kivel 24in Forks and Frame Mini Skid Steer Attachment (A50322)
2025 Kivel 24in...
2012 PETERBILT 367 (A50854)
2012 PETERBILT 367...
AC CHARGING MACHINE (A50854)
AC CHARGING...
