Wider tires on front of 2WD
   / Wider tires on front of 2WD #11
I use wider tires on my MF 135 that I use to feed round bales. It does help with flotation but that means it tends to skate more on turning. The big problem with wider tires is the extra leverage it can assert on the spindles. Bigger diameter is a better way to solve the problem.
Rob
   / Wider tires on front of 2WD #13
Rob
Larger diameter is not going to increase flotation, they will just let you bog deeper before you start to drag the frame. Larger tires carry more load, float better and as for skidding during turning, that is what steering brakes are for.
   / Wider tires on front of 2WD #14
Using the brakes does not work when the differential is locked. Larger diameter keep rolling much longer than small wide tires. The bales I make are about 1000lb FWIW.
Rob
2015 CATERPILLAR AP1055F ASPHALT PAVER (A51242)
2015 CATERPILLAR...
2018 PETERBILT 579 DAY CAB (A51222)
2018 PETERBILT 579...
MIDLAND POLY PIPE REEL TRAILER (A50854)
MIDLAND POLY PIPE...
Unused 2025 CFG MX12RX Mini Excavator (A49461)
Unused 2025 CFG...
(INOP) CATERPILLAR TL943 TELESCOPIC FORKLIFT (A50459)
(INOP) CATERPILLAR...
MAGNUM PRODUCTS LIGHT TOWER (A50854)
MAGNUM PRODUCTS...
