Wider tires on front of 2WD
   / Wider tires on front of 2WD #11
I use wider tires on my MF 135 that I use to feed round bales. It does help with flotation but that means it tends to skate more on turning. The big problem with wider tires is the extra leverage it can assert on the spindles. Bigger diameter is a better way to solve the problem.
Rob
   / Wider tires on front of 2WD #13
Rob
Larger diameter is not going to increase flotation, they will just let you bog deeper before you start to drag the frame. Larger tires carry more load, float better and as for skidding during turning, that is what steering brakes are for.
   / Wider tires on front of 2WD #14
Using the brakes does not work when the differential is locked. Larger diameter keep rolling much longer than small wide tires. The bales I make are about 1000lb FWIW.
Rob
2017 Dodge Charger Sedan (A50324)
2017 Dodge Charger...
PREVIEW DATES AND TIMES (A51572)
PREVIEW DATES AND...
2013 DODGE RAM 1500 FLATBED TRUCK (A51243)
2013 DODGE RAM...
2016 Volvo A25G 20CuYd Articulated Dump Truck (A49346)
2016 Volvo A25G...
2019 Doosan DX225LC-5 Excavator (RIDE AND DRIVE) (VERY NICE) (A50774)
2019 Doosan...
2013 Nissan Sentra Sedan (A50324)
2013 Nissan Sentra...
