Wider tires on front of 2WD
   / Wider tires on front of 2WD #11
I use wider tires on my MF 135 that I use to feed round bales. It does help with flotation but that means it tends to skate more on turning. The big problem with wider tires is the extra leverage it can assert on the spindles. Bigger diameter is a better way to solve the problem.
Rob
   / Wider tires on front of 2WD #13
Rob
Larger diameter is not going to increase flotation, they will just let you bog deeper before you start to drag the frame. Larger tires carry more load, float better and as for skidding during turning, that is what steering brakes are for.
   / Wider tires on front of 2WD #14
Using the brakes does not work when the differential is locked. Larger diameter keep rolling much longer than small wide tires. The bales I make are about 1000lb FWIW.
Rob
2014 CATERPILLAR 336FL EXCAVATOR (A51242)
2014 CATERPILLAR...
2022 Ram Bighorn 2500 4X4 (A52128)
2022 Ram Bighorn...
2019 FREIGHTLINER CASCADIA TANDEM AXLE SLEEPER (A52141)
2019 FREIGHTLINER...
2007 Astec RT-360 Ride-On Trencher Backhoe (A50322)
2007 Astec RT-360...
2016 INTERNATIONAL 4300 24FT BOX TRUCK (A51219)
2016 INTERNATIONAL...
2016 INTERNATIONAL PROSTAR TANDEM AXLE SLEEPER (A51219)
