Wicked Tooth Bar came in today - installed in no time :)
   / Wicked Tooth Bar came in today - installed in no time :) #1
ctgoldwing
Platinum Member
Central Connecticut
L3800HST
I have projects planned for the spring that barring me picking up a backhoe really could use a tooth bar. I've been really pleased with EA's box blade and back blade so that weighed a lot in which one to get. I really don't think it took me more than an hour start to finish. Drilling the holes was the most time consuming part. The mother was heavier than I expected - for someone 74 anyway.
I marked out the centers of the inside slot and used a punch to set a starting point for my drill. I 1st drilled a 1/8" hole followed by a 1/4" then used a varibit to take it out to 3/4". The only 'clever' thing I did, to ensure the bar was seated as far as it could go on the bucket lip, was to snug the bolts then rotate the bucket so the edge was pointed down. Then the bucket was lowered onto a couple of 2X3's placed near the outer edges. I raised the tractor an inch in this way to put as much pressure as possible on the bar. Then tightened as well as I could before putting the bucket back to a raised position. Then tightened the **** out of those 3/4" bolts. The bar is as far back as it can go :)
First check the fit - pretty perfect :)
Drill the pilot holes
The little Dewalt did great
It's hard to believe it fit
Even the other side
Forcing the bar back as far as possible
   / Wicked Tooth Bar came in today - installed in no time :) #2
Very nice. Slick trick on getting it back & tight. You should be pleased with the way it helps. Looks a lot like a HD Piranha TB.
   / Wicked Tooth Bar came in today - installed in no time :) #3
Looks good, I used a block of wood and hammer to get mine tight.
Congrats on the TB, they are so very useful in the dirt and brush.
   / Wicked Tooth Bar came in today - installed in no time :) #4
Yep you will be amazed at what you can do with it. I been getting some mesquite out with mine. They are bout 6-7' tall. Some of them it will pull em right out. What it don't pull it breaks them off then I back tractor in with root grubber on back and it pulls em out. Ground was getting a little dry but we getting some rain today and tomorrow so that will help getting em out. Already got probably 7 piles of mesquites to burn. Makes a **** of a difference on a tractor front bucket.
2011 INTERNATIONAL WORKSTAR 7400 SBA 6X4 DUMP TRK (A52706)
2011 INTERNATIONAL...
2013 Freightliner M2 Box Truck (A59814)
2013 Freightliner...
2015 Freightliner 122SD T/A Wet Kit Day Cab Truck Tractor (A59230)
2015 Freightliner...
2025 HT360W Mini Stand-On Track Loader Skid Steer (A59228)
2025 HT360W Mini...
60'' SKID STEER BUCKET (A56857)
60'' SKID STEER...
2024 JCB 35Z (A60462)
