Why not make a fixed ROPS foldable???
   / Why not make a fixed ROPS foldable??? #31
Jagman, that ROP's looks great, if I was buying your tractor and you labeled that scrap metal I would be bummed out because I would just have to bolt it back on. I have seen alot of welds in my day, and the only difference between a good welder and a certified welder is A PIECE OF PAPER.
Scott
   / Why not make a fixed ROPS foldable??? #32
well. buy the sounds of this, i better not modify my rops... wait. i don't have one... none of our tractors do, except our'70 580 case, and that's only because we modified a tractor cab, that had a rops in it to fit... i'm the 4th generation to run our farmall, a couple of our homemade tractors, and 3rd to run our JD mt, and 420 crawler.... never had an issue, and we spend alot of time on side hills.
this all comes down to the what if's. if it's for your use only, go ahead. plan on replacing the rops if you ever sell the tractor... simple.
   / Why not make a fixed ROPS foldable??? #33
I'm wondering if there is a published spec. for materials and design on a rops. Like tubing diameter wall thickness , mild steel,chromemolly. I put in rollcages in drag cars and NHRA and IHRA specify tubing type wall thickness and how many bars and where they have to atach to. I would think this would be easier specify for a tractor than a race car where every pound makes a difference.
P.S I was at the Richie Bro. 3 day auction last week and saw rops modified on every thing from D8's to skidsteers. ????
Where was the rops police.
   / Why not make a fixed ROPS foldable??? #34
</font><font color="blue" class="small">( but ROPS implementation was done by a complete nitwit (probably in conjunction with a herd of attorneys) who couldn't be bothered to measure the height of the average garage door or person, )</font>
I can't see where Rops implementation should have anything to do with darage door heights. The rops on my 7610 won't fit in my garage.. heck.. the rear tires on my 7610 won't fit inmy garage...thus the rops has no bearing on the tractor going into the garage.. etc..
Darn it.. if only my rops were foldable.. my tractor might make it intot he garage.. right? /forums/images/graemlins/shocked.gif
   / Why not make a fixed ROPS foldable??? #35
I do question if the liability of modifying a ROPS by adding a hinge that duplicated what the OEM does would be any more of a concern than making a repair to a vehicle that was in an accident, for example. Or say welding up a frame on an old vehicle.
The point I was trying to make was that I would be willing to take the risk of modifying a ROPS if I wanted to, as the reality of the matter is that the modification would not weaken the ROPS structure. I know it can be argued that one has not proved that the structure was not weakened, but in a sense it would have been proven by the orginal OEM design which was copied.
I really have no interest in racing cars, but there are people who do this and install roll cages and so on in vehicles for racing/recreational purposes. Is there a liability concern in these cases? I don't know but do know a lot of people are doing these things, and I doubt they are all doing the welding themselves. Many do it themselves, but some are doing it and getting paid to do it for others. How would welding up a roll cage for someone be different than modifying a ROPS on someone's tractor? Granted the roll cage is an addition, while the hinge on a ROPS would be a modification. But both are installed for the same purpose, protection of the operator of the vehicle.
)</font>
I don't get worried about what people do with their equipment. I took the ROPS off my 1720 last year as it doesn't fit inside the barn door I use it in.
Liability is the name of the game. The unibody engine frame on dad's Nova seperated from the rest of the car - only the bell housing was holding the engine compartment on. Noticed it because the clutch would slip - clutch was good, engine compartment was moving..... Anyhow, local mechanic would not fix it for liability, but he found a welder that made brackets - that way mechanic could shift liability to the welder. Also wanted cash on that job, no paper trail.
RR had track bits break, needed them welded. An old-time welder (relative, actually, with _some_ personality....) bragged he was the only one in a 5 state area that would weld them together. Of course, it was liability - no other welder would take it on, this guy welded out of his garage on his city lot for 35 years, doubt he ever had insurance.
So liability does enter into it.
The sanctioning body of the race specifies what roll cage is needed. Pipe size & thickness, number, type of corner gussets, etc. It's all very, very spelled out. The race we help marshal & time had an accident, driver & codriver were killed. SCCA stopped santioning the events, insurance spiked up too high from that. The people building the roll cage have nothing to do with it, as they followed the design spec to the letter. Sanctioning body ends up holding the ball on a deal like that.
Are you using the same welding rod as the OEM? Is the tube any thicker on the new foldable welded ones? Is the base different, to make up for the folding joint? Don't think you can say you are copying 100% what the company did.....
ROPS is a safety device, only purpose. A truck frame is designed for a whole lot more, & needs to meet weight & stiffness specs. Just a different engineering deal.
In principle, I have no problem with you or a qualified welder doing such a mod. It's just that anything that goes wrong is now on your head, not on the original builder. Pretty much the whole story on that. You modify it, & any problems are your problem.
I think most of the words to the wise on this topic is just that - think before you do it, as you will void manufaturer's liability is all.
Was at a farm auction once, was a little IHC A or B tractor (which one is off-centered?) & had a home made belly mower on it. The 2 old batchlor fellas made it with a vertical shaft & a blade - there was no sheilding at all. Even the auctioneer said, I just sell it, I'm not liable for using it!!!! /forums/images/graemlins/smile.gif
--->Paul
   / Why not make a fixed ROPS foldable??? #36
<font color="blue"> Some of us are risk takers and just say change it and don't worry about it. Others are worriers and say don't change it no matter what. </font>
Shall we say "calculated risk" takers. I agree with you post completely but must take the other side frequently.
No one has mentioned bucket hooks on their tractors, yet how may have them? I have to wear a safety hat in my job and have stopped contractors from lifting heavy objects with them because these were add-ons. Working on federal installations, if it aint in the O&M manual, you can't do it. I have argued this point to no avail. Show me in the O&M where it details how to air up my tire. It tells me how much air but not how to do it, do I need to call a service truck to accomplish this? My government counterparts are not impressed.
I have a factory folding ROP's AND BUCKET HOOKS /forums/images/graemlins/shocked.gif. Sometimes I use the tractor with the ROP's down and lift implements with the bucket at the same time /forums/images/graemlins/shocked.gif. But I'm constantly evaluating my environment, and will adjust if I feel the least bit concerned.
   / Why not make a fixed ROPS foldable??? #37
Your Post
I'd suggest that the sleeve method would be safest way to create a substiture for a foldable ROPS providing the insert is long enough and a snug fit and surely superior to any hinge.
My Post
My thought would be to cut a single pc ROPS at the same spot on both sides, and fit a piece of square stock inside the lower half of the ROPS and weld in place. To use the top half of the ROPS, simply slide the top half over the square bar stock and use snap pins to hold it in position. This would be stronger than a hinged assembly. If you were out in the field and wanted to operate the tractor with just the lower half, slide the top half off and use the snap pins to attach it to the lower half. I think it would be quite doable.
I guess we think alike /forums/images/graemlins/grin.gif
scotty
   / Why not make a fixed ROPS foldable??? #38
This subject has been hashed out time & time again. To modify ROPS or not. I side with sound guy & the others against this pratice but, it's yours do what you want, it's your life . If you decide to modify the ROPS , & something happens , it's all on you.
   / Why not make a fixed ROPS foldable??? #39
</font><font color="blue" class="small">( OK, I understand the concerns about modifying a ROPS as far as safety and protection of the operator goes, if the ROPS is called upon to do its duty.
BUT...
Say one would cut his ROPS and have a certified welder duplicate what the OEM does when it makes a ROPS foldable, eg, make the hinge assembly identical, then what's the fuss all about?
What triggered this post is a recent comment by RonX (my X, I forget what the letter should be)(maybe even RonXX). Why fear modifying a ROPS in a way that duplicates what the OEM does anyway?
I would do it. No doubt in my mind. Welding is not rocket science if the welder is capable. Certification = capable, for the most part.
Am I in the minority here? I know about the ROPS police and all that...but...really...
Common sense tells me that exact duplication of what the factory does should not be an issue...
Am I alone here? )</font>
Nice to see you back even with a touch of cabin fever /forums/images/graemlins/shocked.gif
Now, how about "drilling the rops". Was that discussion ever finished? /forums/images/graemlins/grin.gif
   / Why not make a fixed ROPS foldable??? #40
one other option, if you are going to copy a folding rops for your tractor, maybe you can buy one to fit it?
New/Unused Quick Attach Bale Spear (A57454)
New/Unused Quick...
2023 Top Air ATV 200 Gallon Pull Type Sprayer with 30ft Booms (A56438)
2023 Top Air ATV...
New/Unused Fuel Delivery Tank with Pump (A57453)
New/Unused Fuel...
2007 GMC 2500HD (A56436)
2007 GMC 2500HD...
Magnolia Trailer with Adams 25 Ton Fertilizer Tender (A56436)
Magnolia Trailer...
(40) Collectible Watches in Box (A57453)
(40) Collectible...
