Why not a small PTO rock crusher?
   / Why not a small PTO rock crusher? #11
A rock crusher isn’t a cheap piece of equipment and requires a lot of maintenance. You won’t make many tons per hour either. Just buying a load of gravel would look cheap compared to trying to DIY it.
   / Why not a small PTO rock crusher? #13
Go to alibaba.com and search for "rock crusher." 7000+ hits.
That's where I go when I'm in a whimsical mood.
   / Why not a small PTO rock crusher? #14
Are you talking soil tiller/crushers or portable/towable rock crushing plants?
Either way your crusher needs a lot of mass or it will beat itself to death in no time.
   / Why not a small PTO rock crusher? #15
I saw the Chinese one. Still motor driven and the guy had to do a ton of work to it before he could use it.
   / Why not a small PTO rock crusher? #16
It would seem that it would be a benefit of having one's tractor free to move rock while the crusher is operating, unless one has several tractors.
Impact was mentioned. Perhaps rather than PTO driven, one should get a loader with high flow hydraulics and use it hydraulic pump driven.
   / Why not a small PTO rock crusher? #18
So......I watched that Chinese rock crusher video. I guess it would be OK if you wanted to crush rock - as a hobby.
I have a mile long gravel driveway. Local contractor estimated 200 to 250 cu yds of gravel to resurface my driveway. Around 15 to 20 dump truck loads.
If I had sufficient rock to be crushed - crushed rock eight hours per day - don't think I would live long enough to "make" 200 cu yds.
How many have actually witnessed a multiple crushing/screening operation. It is a massively huge/noisy/expensive operation.
For $5000 you can get a whole lot of gravel. Of all sizes, shapes, grades, types - etc, etc.
   / Why not a small PTO rock crusher? #19
Yeah, I thought about that a lot before I bought one.
I hate rocks and I need gravel for my drive, but you're right, I will never produce enough gravel for the driveway.
   / Why not a small PTO rock crusher? #20
steve tyn don't give up just keep crushing rock a little at
a time and you will have a drive way full before you know it
willy
New/Unused CFG Industrial H15R Mini Excavator (A57453)
New/Unused CFG...
Deere 325G (A57148)
Deere 325G (A57148)
2006 Crimson Spartan Fire 105ft. Quint Ladder Aerial Truck (A55973)
2006 Crimson...
Case 950 8 Row Air Planter (A56436)
Case 950 8 Row Air...
23" X 27" ROLLING METAL CART (A58374)
23" X 27" ROLLING...
2018 MQ POWER WHISPERWATT DCA-25 GENERATOR (A58216)
2018 MQ POWER...
