Why is Weight The Only Solution Being Offered To The Problem Of Traction?
   / Why is Weight The Only Solution Being Offered To The Problem Of Traction? #131
Since we have delved down into the physics of how tires work I would like to ask why the front tires are usually so small? I'm thinking the reason being for steering purposes? If it's a silly question forgive me but I figure lets not leave any stone unturned at this point.
Front tires are smaller in diameter than rear tires in no small part because a smaller diameter tire allows for a sharper turning radius with similar axle width as compared to a larger-diameter tire. As was previously stated, a large tire cannot be turned to as sharp of an angle as a smaller tire with the same axle width as the tire would strike the side of the tractor. You would need to have a much wider front axle in order to push the hub of the inside front tire out far enough so that the tire won't strike the side of the tractor when turning. Look at the difference between a planetary-hub MFWD utility tractor and the same tractor in 2WD form. Axle widths are very similar but the MFWD unit will have front tires about 1/3 larger in diameter than the 2WD tractor to give relatively similar ground clearance under the front axle. The MFWD tractor will have a turning radius that is roughly a third wider as a result.
   / Why is Weight The Only Solution Being Offered To The Problem Of Traction? #132
   / Why is Weight The Only Solution Being Offered To The Problem Of Traction? #133
I wonder if there will ever be a tractor/dirt version of Mecanum wheels.
Bruce
   / Why is Weight The Only Solution Being Offered To The Problem Of Traction? #135
Bruce
OK, THAT I've never seen before. Thanks! (y)
   / Why is Weight The Only Solution Being Offered To The Problem Of Traction? #136
They've been around about a decade.
I've never heard them called that, or that brand. But airtrax is a company and they call them omni-directional wheels.
Some of the old episodes of myth busters showed they have a forklift with them
   / Why is Weight The Only Solution Being Offered To The Problem Of Traction? #137
Would have been handy for machine installations at my old job.
   / Why is Weight The Only Solution Being Offered To The Problem Of Traction? #138
Agreed. But they are really expensive and I have never actually seen them used in person. And I have been around hundreds of forklifts from little 4k machines up to 80k machines moving all types of equipment and machinery.
As handy as they look, I bet there's a bit of a learning curve to operating one...lol
   / Why is Weight The Only Solution Being Offered To The Problem Of Traction? #139
Looks like its driven with a joystick?
I'm assuming they are European?
2018 Ford F-150 XLT Sport Pickup Truck, VIN: 1FTEW1EP6JFD27162, Crew Cab, 4 x 4, 2.7 L EcoBoost Gas (A59076)
2018 Ford F-150...
2018 Elgin Broom Badger Sweeper, Kubota Turbo Diesel Engine, 5,888 Hours Indicated, mounted on 2018 (A59076)
2018 Elgin Broom...
2024 CASE TV620B SKID STEER (A52709)
2024 CASE TV620B...
(APPROX. 20) 4' X 8' X 3/8" SHEETING (A52706)
(APPROX. 20) 4' X...
10 - 3/16in Plate Steel Sheets (A55973)
10 - 3/16in Plate...
Club Car Electric Cart (A55758)
Club Car Electric...
