Why break chain on snowblower?
   / Why break chain on snowblower? #1
dutchman56
Northern Ontario
L4630GSTC
When blowing snow on the road to my camp I am breaking main auger drive chain instead of shear bolts. Any others is this a problem. I have a GL4630gstc with 72" front mount blower. I was expecting to pick up some rocks the first couple blows but first time broke chain and shear bolt and second time just chain.
   / Why break chain on snowblower? #2
It would seem the chain is weaker than the shear bolt. I'd try getting a lower grade shear bolt. I don't understand why they put an ungaurded chain on the blowers anyway. Seems like an accident waiting to happen.
   / Why break chain on snowblower? #3
In the snow blowers I've seen there are two sheer bolts. One is part of the main drive line coming from the tractor to the snow blower and protects the drive shaft and gear box. The second is on the secondary drive shaft that runs from the gear box to the auger drive chain. This one protects the auger, drive chain, and secondary drive shaft.
If the chain is breaking, the chain might be weakened and/or the sheer bolt is too strong (too high a grade). On my first snow blower I was breaking chain links and finally took a closer look at it and discovered that essentially all the link straps had fracture lines in them. They were all ready to break. I don't know whether this was caused by some shock load the first time it broke or some other fatigue. After replacing the chain I never had another problem.
As for the sheet bolts, check the owners manual to see what's called for.
The book says 5/16 x 1 3/4 grade 5. Seems hard to me but the chain is 60hd so you would think it could handle it. the second shear bolt is right at the front of second stage impellar and no problem with it sofar but no chain involed with that one.
   / Why break chain on snowblower? #5
If you think of the conditions that snow blowers work under the rust is a rear problem on enclosed shafts. I'd recommend checking both shear bolt locations or three spots. Remove the shear bolt and make sure both halves turn freely and seperately.
   / Why break chain on snowblower? #6
Check the shear bolts and see if they have machined grooves in the smooth section. They are not just plain Jane grade 5 bolts.
Norm
   / Why break chain on snowblower? #7
Norm
This is correct. Mine are this way too.
I thought they would be like on walkbehind blowers. But the orginal bolt with orange paint had no groove.
   / Why break chain on snowblower? #9
Did you lower the skids on your blower and do you set the hydraulics to float when you blow snow? I use a front mounted blower on a gravel driveway and until a layer of hard packed snow builds up this technique works well. Also TSC has a selection of shear bolts that might help solve the problem. One more thought, is the chain tension adjusted properly? A slack chain can break prematurely.
Good luck.
Have skids set as high as possible and chain is the 1/2" play as spec'd. May look for grooved bolts, but will check with dealer first
2003 International 7400 T/A Heil 12 CuYd Dump Truck (A55853)
2003 International...
2007 FREIGHTLINER M2 26FT BOX TRUCK (A59575)
2007 FREIGHTLINER...
2010 CHEVY SILVERADO 3500 HD PICK UP TRUCK (A59575)
2010 CHEVY...
2013 Mack GU713 T/A A-Frame Gin Pole Truck (A60460)
2013 Mack GU713...
JCB 507-42 TELESCOPIC FORKLIFT (A60429)
JCB 507-42...
Flatbed Truck (A55973)
