Who uses .155 line successfully in a string trimmer
   / Who uses .155 line successfully in a string trimmer #22
   / Who uses .155 line successfully in a string trimmer #23
I used .155 on a walk-behind Sears high wheel string trimmer. The kind where you thread two 18(?) inch hanks of string through fittings, which was a time-consuming PIA.
Pure frustration. The .155 might last 5 minutes, sometimes not.
Then the spindle bearing seized so I replaced that.
Sold the miserable thing.
   / Who uses .155 line successfully in a string trimmer #24
My echo high wheel string trimmer is great and it uses up to .190 line. That’s what is needed for trimming tough vegetation. Mine takes 21” string sections and the string lasts a long time IF you cut with the tip of the strings and don’t jamb the whole trimmer into the vegetation at once.
   / Who uses .155 line successfully in a string trimmer #25
Photos at a job this past week. Top one shows why we don't run steel blades.
   / Who uses .155 line successfully in a string trimmer #26
With our cam lock heads, I can change three strings out in 60 seconds.
2004 FORD F-350 SUPER DUTY (INOPERABLE) (A58214)
2004 FORD F-350...
2014 RAM 2500 (INOPERABLE) (A58214)
2014 RAM 2500...
Husqvarna Riding Mower (A56857)
Husqvarna Riding...
UNUSED FUTURE XLA59 - 59" DRUM SPIKE LAWN AERATOR (A52706)
UNUSED FUTURE...
John Deere 1025R (A53317)
John Deere 1025R...
CATERPILLAR CB-224C DOUBLE DRUM ROLLER (A52707)
CATERPILLAR...
